Home > Technical Chat > Primary Gear Endfloat & Radial Cleareance
mikemph
Member #: 449
Oxford
Could anyone tell me the endfloat and the running clearance in the journals of the primary gear. The journal is the most important as I dont seem to be able to find this anywhere.
Mike
turbo hogster
Member #: 178
stowmaket suffolk
i cant remeber but always replace the rear bush with one of mimispares fully floating bearings they are supurb,
I always use the minispares rear bush - and set mu front bush with the same clearance. Axial? Well how much is too much? I generally do it by 'feel' - but there must be an axial clearance stated somewhere...
Stated axial clearance is (I think) 3 to 6 thou, but check in a haynes manual, its in there.
mikemph
Member #: 449
Oxford
Thanks for your help peeps
Gonna order new bushes, set the end float to 0.003"
