| Home > Help Needed / General Tech Chat > Striping and selling engine pricing | |||||||
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
18th Nov, 2013 at 04:46:53pm
Basically had a fairly well spec'd 1293 turbo engine built by steve (benross) and got all the parts to go with it.
cant beat a good blowout. |
18th Nov, 2013 at 04:52:01pm
I'd go gearbox, head, short engine, flywheel/clutch, turbo & manifold, inlet & carb, plenum. If something is worth doing, it's worth doing half of. |
18th Nov, 2013 at 04:52:42pm
if it doesn't sell complete then, head, short engine, gearbox, drops and ancillaries
![]() 270 Posts Member #: 69 Senior Member Coventry |
18th Nov, 2013 at 04:56:19pm
Well I recommend you break down exactly whats in it first, as your idea of fairly well speced doesnt give a whole lot away...never run can be good and can be bad, some would strip it again to see what is in it, check it all and then put it back together and know they did it and at present its all unknown. I would try to sell it complete, easier! but if going to strip it down its ussually head, gearbox, short engine, or if you want to go further crank rods pistons block selling cam and other bits seperately.. but without know whats in it..... |
18th Nov, 2013 at 05:34:51pm
what manifold and turbo is it jamz? |
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
18th Nov, 2013 at 06:41:44pm
After some drops and a good cylinder head mate |
1170 Posts Member #: 8636 Post Whore Surrey |
18th Nov, 2013 at 08:18:22pm
spec list needed for this i think,
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
18th Nov, 2013 at 08:20:32pm
18th Nov, 2013 at 08:21:59pm
I've got few tasty bits I have no doubt about... It was fully built up by Steve ready to drop in and go but never finished build On 27th Apr, 2010 Rick.SPI said:
432 Posts Member #: 7856 Senior Member Essex |
18th Nov, 2013 at 08:57:20pm
I'd be interested in the crank if you split it down to that level, dependent on what it is of course. |
19th Nov, 2013 at 12:17:54pm
would you sell complete? |
19th Nov, 2013 at 12:27:53pm
Yes I wanted to sell it complete but was told to strip as easier to sell and will get more money On 27th Apr, 2010 Rick.SPI said:
19th Nov, 2013 at 06:44:24pm
Could possibly be interested in it complete.
19th Nov, 2013 at 11:08:09pm
As I said, best to give a break down whats in it |
