Home > Technical Chat > Crank Wedging?
seahuston
Member #: 10666
California, USA
Working on a 998 engine and begining to formulate a plan for the next steps of work to be done. I have the crank out and it definitely needs a re-grind. The journals are heavily grooved so I wonder if the engine was run dry or maybe just terribly maintained.
While the crank is out, I was thinking of wedging it. I've got access to a mill and can probably come up with some solid fixturing. In addition, I have a balancing machine I can use to balance it after the fact.
I'm wondering what the general concensus is on wedging. Reports seem a bit varied. I was planning on using the cutting information from vizard unless anyone has better advice. I don't think it would be too difficult once it is setup on the mill. It would be nice to see some examples of a wedged crank if anyone has done it.
this was a thing for 1275 I think, not really neccacary on a 998 IMO
seahuston
Member #: 10666
California, USA
As long as the effects aren't negative I wouldn't mind having a go at it, necessity aside.
Maybe I just have too much spare time...
What rpm are you planning to turn the engine to? under 7k there is definatlely no point.
That said on a 1275 has does a wedged reduce the roughness of running at all? Or does the small amount of weight off the big end make sod all difference in the scheme of things?
998's in general seems smoother running anyway.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i dont think it could hurt?
i believe the big ends on the rods/crank are over weight for what the are so anything taken from them that lightens those parts is good thing?
if you have the proper tooling to do it id do it so long as your staying clear for the parts that are structural and just lop of the "extra" metiral
i agree that if your not turning the thing its much less affective as the force to amplified by rpm
My engine seems to rev easier with a wedged crank, than it did before.
seahuston
Member #: 10666
California, USA
I doubt the engine will see 7k ever so it may not be needed. I will keep looking into the machining end of things.
Replacement crankshafts are NOT cheap so I don't want to mess it up
Here in the uk the 998 can be had for about £20
As said for the road don't even bother, just get all the whole rotating assembley balanced, job done
seahuston
Member #: 10666
California, USA
Thanks for the info all.
Sounds like it really isn't worth it much at all so I will hold off
