| Home > Help Needed / General Tech Chat > adapting for rear beam? | |||||||
![]() 1751 Posts Member #: 10190 Post Whore belgium |
19th Nov, 2013 at 08:43:51pm
hi all
19th Nov, 2013 at 09:31:41pm
Im sure you will be just fine with the coilovers, most come with offset mountings now so no need to modify the rear arches
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
20th Nov, 2013 at 07:00:58pm
Some rear beams require additional mounting holes drilled into the heel board. Not sure if its every beam though, or even if the hole positions are the same with every type David. |
21st Nov, 2013 at 05:53:34am
Seen the offset coil overs now you pointed it out.
23rd Nov, 2013 at 10:16:45pm
You need to make some room at the top of the arch by knocking out the bits that support around the shock. As the coilover will rub on these even when offset. Edited by jonny f on 23rd Nov, 2013. |
23rd Nov, 2013 at 10:24:37pm
My offset coil overs fit straight on without rubbing. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
23rd Nov, 2013 at 11:46:30pm
On 23rd Nov, 2013 jonny f said:
You need to make some room at the top of the arch by knocking out the bits that support around the shock. As the coilover will rub on these even when offset. I had to do this too I seriously doubt it! |
24th Nov, 2013 at 07:44:23am
Owkey.. will look into that... also read somewhere that the top of the arch needs reinforcement. .. so the shokmounts don't rip out. you can do anything if you set your mind to it...
24th Nov, 2013 at 09:07:10am
They wont rip out on the road I seriously doubt it! |
24th Nov, 2013 at 09:36:02am
Its for road and trackdays. But if it won't rip out on road i presume it will be no different on track. you can do anything if you set your mind to it...
24th Nov, 2013 at 09:59:02am
I know a lot of people who have given their cars a lot of grief on road and track with no problems. If you were rallying I would think strengthening would be a good idea I seriously doubt it! |
24th Nov, 2013 at 05:01:54pm
Ill weld up a spread plate just in case. .. will ve to low for rallies. .. thats what i got the black one for. Grts you can do anything if you set your mind to it...
24th Nov, 2013 at 05:02:37pm
Ow other question... are the also easy to set in height like a hi lo? you can do anything if you set your mind to it...
24th Nov, 2013 at 07:07:02pm
On 24th Nov, 2013 Rammie2000 said:
Ow other question... are the also easy to set in height like a hi lo? They sit at the height of the size you order. so a 11 inch coilover will lower the ride height 2 inches vs a 13 inch coilover. springs need to be selected again at the appropriate length to suit the coilover. I Cut down and welded up a rear subframe, then threw it away and made my own to save weight. Currently 3kg lighter than the cut down rear subframe with brackets etc. On 7th Oct, 2010 5haneJ said:
