| Home > Help Needed / General Tech Chat > How tight should a tubo be to rotate? | |||||||
869 Posts Member #: 2443 Post Whore Cheshire |
27th Nov, 2013 at 07:16:40pm
Hi Gents,
27th Nov, 2013 at 07:24:14pm
it should be free, but wont just spin and spin due to the seals.
27th Nov, 2013 at 07:55:59pm
Right it's possibly a little tight then.....certainly doesn't spin freely.
27th Nov, 2013 at 08:00:07pm
a little oil is ok,
27th Nov, 2013 at 08:09:30pm
Thanks Joe ive Just spun it a bit actually and it has freed up quite a bit.....can I strip and clean it or are these things shimmed and adjusted etc.
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
27th Nov, 2013 at 08:19:23pm
you can rebuild them yourself with a kit, as long as you keep the shaft impeller and locking nut in the same position when rebuilt.
27th Nov, 2013 at 08:20:03pm
I would leave it and try it, it probably just needs a bit of oil through it, soon as you start it up you'll blast 40-50 psi of oil through it, that should do the trick!
27th Nov, 2013 at 08:35:11pm
Excellent, thanks gents.
27th Nov, 2013 at 08:37:50pm
Also is it worth keeping the standard compressor bypass valve or should I just blank It off?
27th Nov, 2013 at 08:47:27pm
the exhaust and intake housings are just held on with some bolts or a big circlip, you can just slacken the bolts and move them, the circlips are trickier but can be done.
27th Nov, 2013 at 09:08:54pm
Ahh right so I can just pipe the bypass to the inlet then.
27th Nov, 2013 at 09:43:26pm
I stripped a gt17 that was a little tight, and the bearings were perfect. So needn't have. I fucked it though as I didn't realize the compressor had an anticlockwise thread and snapped the shaft! Edited by minimole23 on 27th Nov, 2013. On 7th Oct, 2010 5haneJ said:
27th Nov, 2013 at 09:59:56pm
This was only a cheapo but to be honest now ive had a closer look it really doesnt look too bad at all. I thought i would buy it for mock up anyway but will probably still go down the route we discussed on PM.
Edited by Andy500 on 27th Nov, 2013. |
27th Nov, 2013 at 10:17:25pm
if you don't plan on using this straight away...it might be worth hanging onto it for a while until someone local might be able to have a look at it for you.
27th Nov, 2013 at 10:18:30pm
dont spin it without oil pressure.
27th Nov, 2013 at 10:27:39pm
What joe said, they pretty much run on a film of oil, not the bearing itself, much like most of the rotating assembly inside your engine. Rotation without oil pressure will definitely knacker it up. On 26th Jan, 2012 Tom Fenton said:
27th Nov, 2013 at 10:34:23pm
Good point chaps....will leave it as it is. Its a TD04 of a Volvo
Certainly it wont do a solid journal turbo much good. Wouldnt do this on a bb item either though! |
27th Nov, 2013 at 10:59:37pm
Ah,
On 27th Nov, 2013 Andy500 said:
Good point chaps....will leave it as it is. Its a TD04 of a Volvo Looks really nice and compact (although i aint got anything to reference it against!) Im hoping to nip over to see Colin in the new year so will take it with me and see what his thoughts are. Is actually much better now ive just turned it by hand a few times. On 28th Aug, 2011 Kean said:
27th Nov, 2013 at 11:07:05pm
Hi Joe, yeah the map looks good plus it was cheap and there seems to be a lot of them about. It might also be easier to get In front of a standard bulkhead as its small
27th Nov, 2013 at 11:18:05pm
Nice. Look forward to seeing how this goes.
In the 13's at last!.. Just |
