| Home > General Chat > high afr on cruise | |||||||
29th Nov, 2013 at 06:26:29pm
just want to check others opinions here...
29th Nov, 2013 at 06:31:49pm
16 afr on the motorway should still be fine but under any load you want to be the other side of stoich imo 14afr or richer
Yes i moved to the darkside |
29th Nov, 2013 at 06:57:56pm
I run around 16.8 to 17.5 to 1 on cruise , you need a powerful spark ,and have to run the plugs around 1.1mm , which is a bit big for high boost . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 293 Posts Member #: 10010 Senior Member Northants |
29th Nov, 2013 at 08:52:36pm
I will agree with the others, it is purely down to the cold temp.
29th Nov, 2013 at 09:19:43pm
this dose not apply to you much but ive not used the aem afr with the mini yet but on my hilux ute
29th Nov, 2013 at 09:27:25pm
have you got the water heated type mani? if so try plumming it up so the flow comes from the head to the mani then to the heater then reterened to the lower hose
30th Nov, 2013 at 03:07:34pm
cheers for the replies. I only use the car in the summer, it was just a late run in it as I had a broken foot for part of the summer so didn't get much use out of the car
30th Nov, 2013 at 03:33:10pm
I have taken Roberts line and run up to 16:1 on cruise (even leaner when just whiffling along in top, in traffic -which is not very often to be fair !)
30th Nov, 2013 at 04:49:55pm
cheers dave (and Robert), I might give this a go. cant see me being out in it before spring now but will look at sorting this for when its next on the road
26th Dec, 2013 at 12:09:57am
Robert, or anyone else who may be able to help...
26th Dec, 2013 at 07:43:47am
it makes it possible to ignite a leaner mix , since the spark is bigger because it has to jump a bigger gap .
Edited by robert on 26th Dec, 2013. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th Dec, 2013 at 12:28:35pm
thanks so much for the reply Robert, its very much appreciated.
26th Dec, 2013 at 02:30:34pm
yes give it a try . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th Dec, 2013 at 03:53:20pm
cheers, I will do. I will take it for a test run in the next week, weather permitting
174 Posts Member #: 9128 Advanced Member |
26th Dec, 2013 at 09:37:45pm
The standard plug gap for the ford ignition system i.e. what your using with the Megajolt is 1mm and is what you should be using anyway. |
26th Dec, 2013 at 09:47:58pm
Cant remember what I set them at before, however they were smaller than 1 mm |
26th Dec, 2013 at 10:13:32pm
On 26th Dec, 2013 DILLIGAF said:
The standard plug gap for the ford ignition system i.e. what your using with the Megajolt is 1mm and is what you should be using anyway. That may be so, but the standard 1.4 Fiesta it came off wasn't running a bar of boost was it .... lol |
26th Dec, 2013 at 10:56:51pm
as above i have had the same issues with some motors and overcome this on the odd engine by setting the plugs to 0.025"
27th Dec, 2013 at 12:22:27am
Cheers gents. The gaps have been reset to 1mm, going to test it soon, if it ever stops raining! |
