Page: |
Home > Non-Mini Discussion > Land rover discovery info. | |||||||
6729 Posts Member #: 618 Post Whore Glasgow |
5th Dec, 2013 at 04:05:46pm
looks pretty smart for the money |
5417 Posts Member #: 6181 Double hard bastard brookwood woking |
5th Dec, 2013 at 06:50:37pm
On 5th Dec, 2013 Rob Gavin said:
looks pretty smart for the money It is mate I am happy with it, also you can't do this in a BMW!! Simon. Edited by madmk1 on 5th Dec, 2013. I have started posting on Instagram also my name on there is turbomk1golf
Site Admin 6263 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
5th Dec, 2013 at 07:04:08pm
Looks good! |
144 Posts Member #: 10557 Advanced Member |
5th Dec, 2013 at 08:43:16pm
i hate the 7 seaters .. bloody rear bulbs are a pain to change.....lol Double-Blind experiment, N:
16540 Posts Member #: 4241 King Gaycharger, butt plug dealer, Sheldon Cooper and a BAC but generally a niceish fella if you dont mind a northerner Rotherham, South Yorkshire |
5th Dec, 2013 at 08:44:40pm
Is that the MK 1's new engine? On 11th Feb, 2015 robert said:
i tried putting soap on it , and heating it to brown , then slathered my new lube on it |
5th Dec, 2013 at 09:09:18pm
Yes I just on bolted them today to get to the bulbs lol.
1170 Posts Member #: 8636 Post Whore Surrey |
5th Dec, 2013 at 11:32:41pm
Looks good fella
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
60 Posts Member #: 651 Advanced Member Rugby, UK |
6th Dec, 2013 at 08:12:14am
I have recently been inducted into the Discovery fraternity...
Forum Mod 10979 Posts Member #: 17 ***16*** SouthPark, Colorado |
6th Dec, 2013 at 12:50:18pm
Nice disco Guessy. Watch out for the exploding front driveshafts... On 17th Nov, 2014 Tom Fenton said:
6th Dec, 2013 at 12:57:11pm
On 4th Dec, 2013 robert said:
I worked on a tdi300 engine , its been running around 30 psi on its stock t25 for 2 years now , with a huge intercooler , in cold weather it wheelspins all 4 wheels in the dry coming out of roundabouts. for those with a poor opinion of the t25 upper boost capabilities ,the difference between 25 and 30 psi is very noticeable..;-0 My experience was markedly different. The engine would make more boost, but just skyrocketed the EGT's and the performance increase for the increases in boost over 15psi was not proportional. Very reminiscent of wringing the neck of a stock metro turbocharger. This was a defender sourced tdi however - but I believed the turbos to be the same? Is the spinning all 4 wheels in the dry a joke? On 17th Nov, 2014 Tom Fenton said:
6th Dec, 2013 at 01:54:07pm
The exhaust manifold is the difference between the defender and discovery tdi's on the Defenders the turbo is Perched rather awkwardly on top of the manifold.
Edited by smokestack-lightning. on 6th Dec, 2013. Double-Blind experiment, N:
6th Dec, 2013 at 03:54:08pm
On 6th Dec, 2013 smokestack-lightning. said:
The exhaust manifold is the difference between the defender and discovery tdi's on the Defenders the turbo is Perched rather awkwardly on top of the manifold. on the discovery its slung in the usual underhand way and is supposed to give a few more hp as standard. That was only the 200tdi - the defender kept the high-mount location the same as the 19J - for reasons I don't really know, but assume it was for parts commonality on the older diesel turbo. For the 300tdi - both engines had the same layout. On 17th Nov, 2014 Tom Fenton said:
6th Dec, 2013 at 04:11:27pm
v true.... dont see enough tdi's these days tis all about the td5's and tdci's at the moment for us. Double-Blind experiment, N:
6743 Posts Member #: 828 Post Whore uranus |
6th Dec, 2013 at 05:29:29pm
no not a joke dave ,but cold weather so less grip. you need a huge ic ,and an adjusted pump tapered cam.
I worked on a tdi300 engine , its been running around 30 psi on its stock t25 for 2 years now , with a huge intercooler , in cold weather it wheelspins all 4 wheels in the dry coming out of roundabouts. for those with a poor opinion of the t25 upper boost capabilities ,the difference between 25 and 30 psi is very noticeable..;-0 My experience was markedly different. The engine would make more boost, but just skyrocketed the EGT's and the performance increase for the increases in boost over 15psi was not proportional. Very reminiscent of wringing the neck of a stock metro turbocharger. This was a defender sourced tdi however - but I believed the turbos to be the same? Is the spinning all 4 wheels in the dry a joke? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
264 Posts Member #: 11029 Senior Member Crewe |
7th Jan, 2015 at 10:39:20pm
i run a 300tdi defender with a replacement discovery engine no egr and a derv pump tweek
Edited by monsterob on 7th Jan, 2015. Outside the box |
109 Posts Member #: 10368 Advanced Member Australia |
8th Jan, 2015 at 08:59:56am
looks like a good find. I had a tdi300 for 18 years, i just couldn't kill it. Some of the plastic items weren't great in the end and there was some trickery in the electrics at times but in terms of good solid dependable vehicle that could tow (albeit slowly) it was terrific. I had just decided to keep it until she was twenty when someone T boned it. Each major service gets more interesting ...as it is worth relatively little to anyone else , so you have to scratch the head when 4 new tyres are worth more than the car as a total.... Good luck Edited by Earwax on 8th Jan, 2015. |
4300 Posts Member #: 1321 Post Whore Wiltshire |
8th Jan, 2015 at 09:13:55am
Sold my tdi defender about this time last year. Epic mistake! On 7th Oct, 2010 5haneJ said:
Page: |
