| Home > General Chat > Modification from biased needle to fixed needle | |||||||
![]() 243 Posts Member #: 89 Senior Member Sydney Australia |
3rd Dec, 2013 at 09:09:15pm
Hi Guys,
179hp on 12psi 1293cc of pure A series
3rd Dec, 2013 at 10:30:07pm
Never done it myself. Can i ask why you'd want to?
3rd Dec, 2013 at 10:44:06pm
You can convert a biased needle to a non biased needle so that it will fit in a non biased needle carb.
![]() 1751 Posts Member #: 10190 Post Whore belgium |
4th Dec, 2013 at 08:22:06pm
Exept if you like the hard adjustment work? How would you centralise the jet in the bridge then? Stromberg carbs have a fixed needle (some of them) but the jet can be adjusted to centre. From underneath. you can do anything if you set your mind to it...
4th Dec, 2013 at 08:40:06pm
the older HS2 and HS4 carbs have a fixed needle.
4th Dec, 2013 at 09:33:46pm
Colin, I always thought that the idea of a swing needle was so that it did not need to be accurately centred on the jet ? (They will meter the same as any other surely, until they wear a bit off the side of the jet, as they do)
4th Dec, 2013 at 10:51:56pm
Yeh your right Dave. I've just looked at the assembly procedure of a HS and it does explain centering the jet, but it looks fairly simple to do so. Its been 20 years since i had a play with a HS carb though and 10 years since the last time I had a HIF appart lol.
5th Dec, 2013 at 10:27:34am
The reason a biased needle meters fuel more accurately is because the shape of the annular space between needle and jet will always be exactly the same shape, just varying in size as the piston and needle goes up/down. The shape is effecticely a "C" thick in the middle and thinning to nothing at the ends, just increasing uniformly in thickness at the needle rises.
5th Dec, 2013 at 11:20:17am
Thank you Rod for a clear and concise explanation as I did not understand how the swing needle could be better - I do now.
5th Dec, 2013 at 11:26:19am
I have just had another thought.
5th Dec, 2013 at 01:12:10pm
David,
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
5th Dec, 2013 at 03:12:48pm
Burlen sell a kit to do the conversion.
Metric is for people who can't do fractions. |
5th Dec, 2013 at 03:18:44pm
Thank you Rod - that confirms my own thinking (without the technical understanding !) |
