Home > Technical Chat > Rubber cone tool
evad1980
Member #: 10165
Stansted, Essex
Hi all,
Went to minispares today and forgot the rubber cone tool I meant to buy.
Is it possible to put the front subbie back together without this tool? I'm thinking no as I struggled this evening without it?
Just trying to save myself a trip back there tomorrow.
Cheers. Dave.
If the subframe is off im sure you could make some sort of heath robinson device with a bit of thredded bar and some washers.
Is there no one local in Jupiter that may have one to borrow
rick
If your fitting Hi-Lo's you should be able to wind them all the way down and get the top arm in, then slide the pin in.
evad1980
Member #: 10165
Stansted, Essex
It's a bit scarce up here in Jupiter!
Heath Robinson? Who's he lol?
Joe.... Do you mean with the subbie in situ?
can be done with the subby in situ, but top arm pin access is a PITA if you have inner wings.
evad1980
Member #: 10165
Stansted, Essex
Ah yes.. I know what you mean, I had the top arm in already, no way getting it in like that!
I'll head to the garage I think!
evad1980
Member #: 10165
Stansted, Essex
Heath Robinson... Just googled him.. Cool!
