| Home > Technical Chat > clutch plates | |||||||
6th Dec, 2013 at 03:38:46pm
I've currently got a paddle plate in the RTS in the mini but its not the smoothest for a road car. Power is not daft so don't really need the current plate.
6th Dec, 2013 at 03:53:04pm
I just used a standard turbo solid plate.
6th Dec, 2013 at 05:32:24pm
the normal turbo plate span massively around 200lbs/ft. the ap racing rally plate is fine above that to 250lbs/ft odd. Edited by robert on 6th Dec, 2013. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
6th Dec, 2013 at 05:35:58pm
Robert? Do you know the friction coefficient for the AP rally plate? On 26th Oct, 2004 TurboDave16v said:
6th Dec, 2013 at 06:46:46pm
Rob, what paddle are you using? I use the minispares 5 finger in my pre verto setup, the grey diaphragm makes it a bit heavy but its not too bad
6th Dec, 2013 at 08:41:07pm
On 6th Dec, 2013 Sprocket said:
Robert? Do you know the friction coefficient for the AP rally plate? not one verified by ap.
7th Dec, 2013 at 11:08:48am
On 6th Dec, 2013 welshdan said:
Rob, what paddle are you using? I use the minispares 5 finger in my pre verto setup, the grey diaphragm makes it a bit heavy but its not too bad have always used the verto ap race/rally plate in my na cars, these feel pretty much standard, but don't have any usage of one in a high powered turbo a series. cheers, dan |
