| Home > General Chat > Sand Blasting | |||||||
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
9th Dec, 2013 at 07:58:50pm
usually only use my cabinet for getting rid of rust and general snot but but going to do all the alloy bits, inlet manifold, thermostat housing, bell housing etc but not sure which media to use i.e sand, grit, glass beads. Does anyone else use a blast cabinet and if you do what do you se to clean aluminium stuff? Masturbation is not a crime its a hobby |
9th Dec, 2013 at 09:02:14pm
sand, you can get it from machine mart its not expensive
9th Dec, 2013 at 09:14:35pm
what is reccomended to blast the gearbox casing back to shiny aluminium?bead blasting? is the best way to stop it oxidising then to laquer it? On 7th Oct, 2010 5haneJ said:
9th Dec, 2013 at 09:15:53pm
just ordered a load of gearbox parts so want it all to look good too On 7th Oct, 2010 5haneJ said:
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
9th Dec, 2013 at 09:20:15pm
glass beads for ally, sand or the various oxide grits for steel, I did laquer mine . Edited by oli79 on 9th Dec, 2013. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
9th Dec, 2013 at 09:58:31pm
You could use kiln dried sand. Only kiln dried though as regular building sand is wet and clumpy and pretty useless for blasting. On 26th Jan, 2012 Tom Fenton said:
9th Dec, 2013 at 10:39:40pm
thanks for the replies lads. Will give beads a go then....not the ann summers kind tho Masturbation is not a crime its a hobby |
![]() 270 Posts Member #: 69 Senior Member Coventry |
9th Dec, 2013 at 10:47:22pm
used kiln dried before and works out really cheap compared with machine mart stuff. |
9th Dec, 2013 at 11:04:13pm
kiddies play pit sand |
126 Posts Member #: 10212 Advanced Member Sleaford Lincolnshire |
10th Dec, 2013 at 07:11:41pm
I thought sand was a No No due to the silica dust getting in your lungs
Edited by Jawd on 10th Dec, 2013. |
10th Dec, 2013 at 07:23:31pm
You should be wearing respiratory gear using whatever you blast with so i wouldn't have thought it would be much of an issue. On 26th Jan, 2012 Tom Fenton said:
10th Dec, 2013 at 08:15:03pm
On 10th Dec, 2013 Jawd said:
I thought sand was a No No due to the silica dust getting in your lungs Jawd I've got a blast cabinet so thats not a problem. I'm bone idle and dont like wire brushing and sanding so a sand blasting cabinet is a god send Masturbation is not a crime its a hobby |
