Home > Help Needed / General Tech Chat > average boost pipe size ?
oliver122
Member #: 9625
hi guys , atm im sourcing parts for an eventual turbo build , and ive got my hand on a plenum , carb and a set of omega 1293 pistons with a 10cc ish . anyway while i run my na engine i thought i would utilise a plenum to make an induction system as the roar of a k&n behind the bulkhead is abit aggravating (also i just fancied messing) now my idea was to replace the gonzo nose on the plenum with a 90ish degree bend to come round the carb and towards the clutch side then i can run a length of boost pipe with a filter on the end . so what is the average boost pipe size people run on there turbo mini ?
t@z
Member #: 452
Chester, UK
erm i think the plenum is 45mm ID and my turbo is 53 ID... i think :/
www.twitter.com/lilpinkiy
Most use the 52mm silicon
mine was 63mm and an adapter either end
I think of the top of the top of my head, my pipe is 52mm
oliver122
Member #: 9625
cheers guys , so if i buy some 52 mm pipe t should be a snug fit ?
No. The "Gonzo nose" is 45mm. Most folk adapt up to 52mm as its more commonly available in silicone and alloy pipes.
If you're trying to use the plenum as some sort of inductin system for an NA engine, don't bother.
oliver122
Member #: 9625
well i will be useing it for boost later on , but i thought i would give it a go , how come lizard ?
I'm guessing because it has a restrictor ring, so it's probably going to throttle down your inlet size, not a problem on boosted engines as the pressure forces the air through.
