Home > General Chat > Good results today at Lynx racing
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
went for another tune up today with larger injectors, I'm only running 1 bar boost (14 psi) with Benross special head on a 1380 bottom end, Help from Neil fromPolestar with his ecu and specialist components Injection, cossie 4x4 intercooler, the blower comes in nice and early and produced 208 @ 6500 rpm.
Very happy, kept the boost low due to oil getting a bit warm, will improve on this and try for more another time, there was deco more to come from the engine.
16V project underway
That's good going that mate well done! 208bhp on 14psi!! What turbo was that with if you don't mind me asking.??
Simon.
Turbo Tim
Member #: 177
Woburn Sands
lol, going to keep that one to myself for a bit
that really is some figure mate, whats the fuel distribution like with the SC injection at that power any ideas?
what size injectors? im considering the sc spi settup for my bros engine
Edited by Brett on 21st Dec, 2013.
Fair one mate, so at 20psi you could be the first 300bhp mini lol.
Turbo Tim
Member #: 177
Woburn Sands
I had to dump the 470 injectors for some Asnu 750cc ones, plenty of supply then
Turbo Tim
Member #: 177
Woburn Sands
going to sort the oil cooling out first before pushing it
Yes I found my oil temps was very very high before I fitted a cooler.
Superb result that tim.
Any pics !!!
rick
Turbo Tim
Member #: 177
Woburn Sands
would post the power chart if i knew how
Nice.
Turbo Tim
Member #: 177
Woburn Sands
i have a cooler but think i fit 2 under the boot floor and see how that works
Turbo Tim
Member #: 177
Woburn Sands
Powergraph
http://s1336.photobucket.com/user/timinitu...449832.jpg.html
Edited by Turbo Tim on 21st Dec, 2013.
a single 9 row i think mine is took my temps down from 125-130 to under 95 degC
that was a steady 60mph cruse lol
with the oil cooler fitted i no longer had to worry about cooking my oil on the motorway
Turbo Tim
Member #: 177
Woburn Sands
having 2 coolers in the rear will help, plus more oil in the system
welshdan
Member #: 1111
s wales
Well done tim, mad power there! Great result. How is it on the road?
excellent stuff tim, theres a lot more to come out of this engine buddy....... keep us all posted, the cossie intercooler with not much restriction this does help massivley!
Do you run a straight cut box?
Turbo Tim
Member #: 177
Woburn Sands
yes, you have to with this much power, metro challenge set
Just managed to get a look at the sheet there is alot of power loss through the box is it still ok?
Turbo Tim
Member #: 177
Woburn Sands
yes box is all good, fresh build
Do the lynx rollers measure transmission losses Tim or is it just a best guess at 20%?
lee.pb
Member #: 9199
Lancashire
Awesome result there Tim.
If you copy the IMG code off photobucket and paste it in a trend it should show up without having to click on it.
Remember to delete all the other text apart from the text between the two IMG tags, these need to be left in too.
Just a bit of fun with excel.
Edited by lee.pb on 22nd Dec, 2013.
nice job!
what diff is that on tim ?
Turbo Tim
Member #: 177
Woburn Sands
3.1 fd
