| Home > Help Needed / General Tech Chat > K1100 conversion block prep. | |||||||
![]() 9 Posts Member #: 10692 Junior Member Omagh Ni |
23rd Dec, 2013 at 10:30:58pm
Hi folks
26th Dec, 2013 at 04:34:48pm
hi, have a look at my build. for the plugs you will need cast iron rod threaded to 3/8 unc, you can't use the head studs as the drill will slip. for the oil ways I went to the local plumbers and got some 1/8th brass studs. however if I was doing it again, I would make the plugs bigger and drill right into them rather than half the stud and half the block. Use plenty of locktite. hope that helps. also buy some arp head studs. you will notice the difference when putting the head on. |
29th Dec, 2013 at 08:20:50pm
Cheers Phil
