Home > Beginners Tech > bosch fuel pump R18366A fuel inj pump
Steve A
Member #: 7876
Walsall West Midlands WS1 2DW
I have the above fuel pump but can find no info on it and was wondering if it would be fit for turbo use. I have no fuel pressure gauge or anyway of knowing the ltrs delivered hence this post cheers Steve
Patina=old and knackered and won't clean up
thats a reno 5 turbo pump so will be fine
Steve A
Member #: 7876
I was told by the supplier it was a fuel injection pump?
Cheers Steve
basically it is,
carbed turbo's usually use an injection pump but just a reg set to 4 psi.
this is the R5 pump, what you have is an equivalent, or slightly uprated.
http://www.fuelpumpsonline.co.uk/bosch-fue...64070-192-p.asp
Steve A
Member #: 7876
