Home > General Chat > aftermarket alternators and radiator brackets
welshdan
Member #: 1111
s wales
hi chaps, hope you are all having a great xmas
I am considering playing about with the turbo install on my car, and will need a small alternator in order to do this.
I know there are some threads on here but not looked into this before - was wondering what small alternators people have used, and where the best suppliers are?
also I will be looking at moving my rad (std position) closer to the inner wing - can anyone advise if there are such brackets in existence to do this? if they can be bought off the shelf great, if not I can make something up.
thanks a lot, dan
welshdan
Member #: 1111
s wales
do these look any good?
cheers, dan
http://www.ebay.co.uk/itm/Genuine-Nippon-D...=item3a85da3d78
dev 11
Member #: 9393
stoke on trent
Same alternator I got, managed to get mine new boxed about 40quid.
I'd whip up some brackets or maybe clubman bracket Is wider
welshdan
Member #: 1111
s wales
cheers mate. was yours new from a supplier or did you get a good deal second hand/in a group buy? cheers, dan
http://www.turbominis.co.uk/forums/index.p...id=294168&fr=75
Have a look hare mate and see what I did
welshdan
Member #: 1111
s wales
thanks simon. my brother runs something very similar on his car. he made the brackets up when he had access to forming/bending tooling.
im going to go and have a look in the garage later, to see if the new intercooler that I have will even fit, even after moving things about. if it looks promising I will look at getting some 90 degree angle alloy. I know that this will not just bolt on (think my brother said that the front bracket certainly has more than a 90 degree bend, tapering towards the top, but it should be a good place to start.
cheers, dan
Have a look in my build thread. They are easy to fit.
Yes I did it by hand in the end as I could not get it right.
welshdan
Member #: 1111
s wales
have spent half the day down the garage. I need to get some more work done to my intercooler end tank, it may be that I don't need to relocate anything yet. going to see how the intercooler turns out before moving the rad and changing the alternator, it may not even be reuired
Rick.SPI
Member #: 8027
I got a nippon alternator from rbay, one of the cheaper ones, its now fucked... So went and got a genuine one. Expensive mistake.
