| Home > Help Needed / General Tech Chat > Hi-Lo dimensions / diameter | |||||||
1170 Posts Member #: 8636 Post Whore Surrey |
27th Dec, 2013 at 08:42:41pm
anyone have one to hand to measure the diameter where the donut would sit?
Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
27th Dec, 2013 at 09:00:19pm
i can give it tommorow morning you can do anything if you set your mind to it...
28th Dec, 2013 at 07:50:36am
The ones i have here measure 57.25 mm and go in11 mm. you can do anything if you set your mind to it...
28th Dec, 2013 at 12:27:26pm
Perfect Thanks Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
28th Dec, 2013 at 09:26:31pm
no problemo. glad for once i could help instead of asking questions... ;-P you can do anything if you set your mind to it...
29th Dec, 2013 at 12:34:39am
the width of the seat that presses against the donut is important too, and it seems to vary between gen/non gen hi-los :) turbo 16v k-series 11.9@118.9 :)
29th Dec, 2013 at 07:20:09am
I have some different types. All of them have a full seat up to the bolt in the centre. Don't have an original though. you can do anything if you set your mind to it...
976 Posts Member #: 3228 Post Whore North of the Netherlands |
29th Dec, 2013 at 10:45:33am
I had a look at the ones I have; see picture below.
Dazed and Confused.... |
29th Dec, 2013 at 11:20:56am
Ow shit yes. The ring to the outside. Not inside. My mistake. you can do anything if you set your mind to it...
29th Dec, 2013 at 11:59:41am
Cheers again Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
i have the ripspeed one
