| Home > Help Needed / General Tech Chat > Gear position for dash board | |||||||
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
28th Dec, 2013 at 12:16:39am
Hi guys,
David. |
28th Dec, 2013 at 12:39:13am
Mine has 2 magnets that you mount to say the pot joint and pick up sensor. You then have to tell it what gear you are in at certain revs, and from that it'll know what gear you are in from the engine revs and wheel speed. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
28th Dec, 2013 at 12:52:24am
Which dash do you have matty?
David. |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
28th Dec, 2013 at 09:33:56am
OT but had a gear indicator on my sports bike.
28th Dec, 2013 at 10:27:34am
cant MS work your gear out in that same way compare wheel speed to engine speed of coarse you would need a wheel speed sensor.
28th Dec, 2013 at 11:48:42am
Thats the basic way I read about it, have to input your gear ratios, diff ratio and wheel circumference.
On 28th Dec, 2013 lee.pb said:
OT but had a gear indicator on my sports bike. It worked as Matty says comparing speed (wheel rotation) against revs. Basically you calibrate it in each gear at 2k then it works its own gear indication out. But the bike did have a neutral light that connected to it. You could fool it by pressing the clutch and reving the engine while moving, making it think its in another gear but sorted its self out once you released the clutch. David. |
28th Dec, 2013 at 03:01:03pm
Mine is this one.
