Home > Help Needed / General Tech Chat > DSN/RetroSport Timing Cover setting up Cam end float
NickG
Member #: 7912
Australia oi oi oi!
hey lads.
Im confused I just replaced the cover with the Dsn one & I'm putting it back together with the same cam gears & chain/
How do i check the cam shaft end float using this cover, engine is in the car.
I can't really get a feeler gauge behind the cam gear.
I can't seem to see or tell what or where the feeler gauges are hitting, behind the cam gear, with the Retro sport timing cover back plate.
HELP? using same cam gears as before & cam plate. so would it be the same end float still?
Edited by NickG on 28th Dec, 2013.
Use a dti guage
graemec
Member #: 1424
Carnforth, Lancs
The cam end float shouldn't be affected as it is set by the size of the shoulder on the sprocket sitting against the cam. However alignment between the two sprockets probably will be.
