| Home > Help Needed / General Tech Chat > intercooler mounting help | |||||||
337 Posts Member #: 9138 Senior Member wolves |
28th Dec, 2013 at 02:47:13pm
i am mounting my cooler in the grill of a clubby fiberglass front
28th Dec, 2013 at 03:24:58pm
i made solid stainless mounts for my cossie 2wd one. though on a trip to the rollers it had to come out, to do leakdown etc. I never bothered using the mounts again, just left it in the engine bay! at full chat on the rollers the cooler didn't move at all, the hoses were bulging massively though, looked like they would pop!! |
28th Dec, 2013 at 11:03:13pm
not an IC but mounted mine on some i think exhaust hanger or shifter mounts they just have a thread out each side with rubber in between not used the car tho but i think it will be good as there is a bit of give yet held still just one each side and the top is supported from some 3mm? rod bent with some thick rubber hose for a bush n a plate to mount under some std bolt holes
28th Dec, 2013 at 11:48:32pm
you need to mount the cooler so its tied to the engine and not fixed to the bodywork, many peeps make this mistake fixing it to the body work and when the engine rocks about it fooks it all up, ... even it the engines welll mounted & secured correctley!!
Edited by BENROSS on 28th Dec, 2013.
29th Dec, 2013 at 05:35:41am
my understanding was the silicone boost lines had enough give to be ok
29th Dec, 2013 at 10:41:13am
Rubber mounting the intercooler to the body is the way to go, the hoses will have enough give.
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
29th Dec, 2013 at 11:26:34am
On 29th Dec, 2013 Turbo This.. said:
my understanding was the silicone boost lines had enough give to be ok your advising that i make some solid brackets to the block and rubber mount rads to that? ive not got to much space to work with None of us do, we all own minis LOL ![]() ![]()
BHP sells engines, but Torque wins races! |
