| Home > Help Needed / General Tech Chat > Minispares rodchange oil leak fix kit | |||||||
133 Posts Member #: 476 Advanced Member The Black Countraaaaay |
29th Dec, 2013 at 01:42:44pm
am I being really thick or missing a trick. Got my oil fix kit from minispares that has the alloy support ring with rubber o ring but when I tried to put it all in the diff cover case the depth of the ring plus oil seal is way too much for where the usual oil seal goes. Masturbation is not a crime its a hobby |
29th Dec, 2013 at 01:53:43pm
Is there one already in there? On 11th Feb, 2015 robert said:
![]() 1751 Posts Member #: 10190 Post Whore belgium |
29th Dec, 2013 at 01:54:58pm
We tend to use to rubbers instead of de aluminium one. Guarantee no more leak. you can do anything if you set your mind to it...
29th Dec, 2013 at 02:23:29pm
With mine, I left everything as it was but hammered another seal in as there's room for two. Solved it for me. On 26th Jan, 2012 Tom Fenton said:
29th Dec, 2013 at 03:04:59pm
I'll go with the yamyams advice then Masturbation is not a crime its a hobby |
29th Dec, 2013 at 03:44:15pm
Depends on the age of the gearbox as Austin Rover implemented such a 'fix' as standard. They still leak lol. On 26th Oct, 2004 TurboDave16v said:
29th Dec, 2013 at 05:47:41pm
You can get up to three seals in there !
13th Nov, 2017 at 10:33:21pm
Old post I know but always seem to suffer from this area leaking.
My build thread..
261 Posts Member #: 713 Senior Member Western Australia |
14th Nov, 2017 at 02:44:42am
Nope. On 24th Dec, 2008 Nic said:
eyh? im drubj but very confused##]#IU |
19th Nov, 2017 at 10:16:38pm
The aluminium bush with the O-ring on the outside could be improved with an O-ring on the inside. Personally, I'd make my own and use a smaller cross section O-ring on the inside and outside of it On 26th Oct, 2004 TurboDave16v said:
