| Home > General Chat > Diff pin wear | |||||||
976 Posts Member #: 3228 Post Whore North of the Netherlands |
29th Dec, 2013 at 01:54:09pm
I have seen some wear on diff pins before, but this is what a friend pulled out of a diff Dazed and Confused.... |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
29th Dec, 2013 at 01:57:23pm
29th Dec, 2013 at 02:16:14pm
That's a good one that! I have started posting on Instagram also my name on there is turbomk1golf
29th Dec, 2013 at 03:19:13pm
Lucky that held out! |
29th Dec, 2013 at 03:32:00pm
I've seen something similar before. Usually loss of drive is experienced suddenly with the remains of the diff pin spat out through the diff casing and dumping the oil.
29th Dec, 2013 at 03:32:02pm
Holy shitballs batman, that's some wear! On 26th Jan, 2012 Tom Fenton said:
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
29th Dec, 2013 at 04:22:37pm
Bloody Nora! That can't be from regular wear and tear, surely? |
29th Dec, 2013 at 04:32:53pm
Too many emergency starts On 11th Feb, 2015 robert said:
![]() 178 Posts Member #: 10196 Advanced Member |
29th Dec, 2013 at 05:20:03pm
ive seen a fair few my mates stripped out of young lads cars, we now have a wall of fame |
29th Dec, 2013 at 05:22:24pm
it was a good catch... I run a supercharger and I don't care the TB is on the wrong side.
656 Posts Member #: 1917 AKA chargedzetec Milton Keynes |
29th Dec, 2013 at 05:42:09pm
That's a good effort. This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
29th Dec, 2013 at 06:11:56pm
bennys was about that bad when he bought his mini Yes i moved to the darkside |
![]() 324 Posts Member #: 9441 Senior Member South Devon |
29th Dec, 2013 at 06:16:30pm
J turns ahoy. |
![]() 293 Posts Member #: 10010 Senior Member Northants |
29th Dec, 2013 at 06:27:54pm
Yeah that'll go back in, plenty of miles left in it! |
29th Dec, 2013 at 07:21:13pm
We need a section of forum to show shit like this off!! :) nice effort! |
30th Dec, 2013 at 01:07:20am
how about the thrust cups? non exist ant?
32 Posts Member #: 2150 Member |
30th Dec, 2013 at 01:48:30am
Looks like one of those uprated ones, from a few years ago. I've got one that looks the same. |
30th Dec, 2013 at 08:19:05am
On 29th Dec, 2013 Sprocket said:
I've seen something similar before. Usually loss of drive is experienced suddenly with the remains of the diff pin spat out through the diff casing and dumping the oil. Just so you know for future maintenance, checking for wear in the diff pin is easy. Jack one of the front wheels up leaving the other on the ground. With the engine in gear, turn the raised wheel back and forth. lots of movement here indicates wear in the diff that needs looking at quick. Nice info. To me it's a clear example of when you get an engine that doesn't have detailed history and you want to run it for a longer time you need to pull it appart.. (especially when someone gives it to you for free! )
On 30th Dec, 2013 Turbo This.. said:
how about the thrust cups? non exist ant? can the out put bits be saved or have the teeth been chewed up by planet gears? Well let's put it this way, as this is how the crank mains look like I wouldn't use anything near the diff again.. especially as there's enough diffs around.
30th Dec, 2013 at 08:39:05am
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
30th Dec, 2013 at 10:41:38am
I've never seen one that worn without snapping !
Metric is for people who can't do fractions. |
30th Dec, 2013 at 06:08:47pm
how about the thrust cups? non exist ant? can the out put bits be saved or have the teeth been chewed up by planet gears? Well let's put it this way, as this is how the crank mains look like I wouldn't use anything near the diff again.. especially as there's enough diffs around. ![]() my mate snapped his crank on the way back from Malvern on the m6 just before junction 14, luckily we only had to get it to stoke, but it was funny a moke towing a moke with a make shift tow rope. Engine would still run! |
30th Dec, 2013 at 06:28:58pm
I think it looks worse than it actually is.. Dazed and Confused.... |
