| Home > Help Needed / General Tech Chat > Lowering engine position in subframe | |||||||
976 Posts Member #: 3228 Post Whore North of the Netherlands |
31st Dec, 2013 at 12:18:20pm
Hi all,
Dazed and Confused.... |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
31st Dec, 2013 at 02:30:19pm
Solid mounts will transmit horrendous vibrations through the car, and potentially shake & break things you didn't even consider possible.
Metric is for people who can't do fractions. |
31st Dec, 2013 at 04:12:23pm
Thanks for that input Alex.
31st Dec, 2013 at 04:18:57pm
rad side is easyish as you have the two bolts through the ally block, you can just file the holes out a bit,
31st Dec, 2013 at 04:33:42pm
Would it be worth thinking about lowering the whole subframe if 5mm is all you require? You could easily make up new solid mounts to accommodate that, or modify some of the existing. On 26th Jan, 2012 Tom Fenton said:
31st Dec, 2013 at 04:40:08pm
if anything you wanna raise the suby to get better susension angles/ travel. On 28th Aug, 2011 Kean said:
31st Dec, 2013 at 04:57:14pm
I know joe, just thinking outside the box, maybe he could raise the subby by a couple mm and then lower the engine by a couple of mm so it doesn't really compromise anything if that makes sense. On 26th Jan, 2012 Tom Fenton said:
1st Jan, 2014 at 09:40:16am
Thanks for that lads.
1st Jan, 2014 at 10:20:28am
The auto subframe is very wide at the point where the engine mounts bolt in so you will have to fabricate spacers - these will determine how much the engine will drop. If it were me I would rather modify what is already there since fabrication is needed whichever subframe you use.
I seriously doubt it! |
1st Jan, 2014 at 10:45:09am
If you don't use spacers on an auto subframe, could you not just drill the engine mount holes further down the subframe rails at the point where the width matches a normal subframe?
1st Jan, 2014 at 10:47:19am
Its too wide for that
Edited by paul wiginton on 1st Jan, 2014. I seriously doubt it! |
1st Jan, 2014 at 11:13:50am
I think I have about 5mm of spacers in my auto sub in the spud. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1st Jan, 2014 at 11:18:44am
On 1st Jan, 2014 robert said:
I think I have about 5mm of spacers in my auto sub in the spud. Wow, I worked on a car once that had 1". It was a long time ago, I wonder why there was so much difference I seriously doubt it! |
1st Jan, 2014 at 11:21:36am
I used 4mm spacers between the engine and standard engine mountings rather than between the subframe and engine mountings. Makes it easier to fit the engine. This drops the engine mounting holes immediately below the original holes in the auto subframe and equates to ~ 1/2" drop of the engine in the bay. On 26th Oct, 2004 TurboDave16v said:
1st Jan, 2014 at 08:06:37pm
Thank you all very much in contributing to a sollution.
1st Jan, 2014 at 08:42:46pm
It should be easy to identify the auto frame as it will have a cranked cross member at the front and the distance between mounting holes on one side is wider than standard manual mountings, *edit again* i'm not sure which side Edited by Sprocket on 1st Jan, 2014. On 26th Oct, 2004 TurboDave16v said:
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
2nd Jan, 2014 at 12:32:50am
don't fit solid mounts, had them on a mini years ago and the noise was horrid.. vowed i never would again. BHP sells engines, but Torque wins races! |
