Home > Introduce Yourself > New to TM
Gomme
Member #: 10528
Denmark
Hi from Denmark :)
Hi all, new to the site but not to the cars :)
Old engine 1293 SPI with an old Turbo technichs T3 kit, with carb mounted on the side of turbine housing
New engine under assembling: 1293 MPI, with Emerald K6 ECU, cylinderhead still stock :(, custom exhaust manifold, GT-17 turbo, omega pistons, MED ultra light flywheel, MED verto heavy duty (hopefully it works well), transmission stock from old engine.
Ordered a bespoke kit from a shop in the UK, was not happy when it arrived, so had a new exhaust manifold done by a good friend of mine :).
Anyone here who have tried to run with boost, on the stock MPI inlet manifold???
Morten
Edited by Tom Fenton on 2nd Jan, 2014.
lee.pb
Member #: 9199
Lancashire
Welcome to TM
Beno174k
Member #: 9548
Manchester
Heyyyy
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=445578
Welcome
How do
welcome to tm
Hello and welcome !
APS
Member #: 10369
Pickering, North Yorkshire
Now then :)
www.apsbikes.co.uk
Welcome
carl
hazpalmer
Member #: 9038
Carlisle, Cumbria
welcome
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
Hello Fellow countryman.
You have found the right forum *smiley*
If i have more toys than you when i die, I WIN
Welcome.
I've just fitted a MPi inlet to a 998 with MS3.
Manifold wise it is good but will not fit with the Metro Turbo exhaust manifold.
The throttle body is poor. Plastic, so may not hold under boost. Plus it is very restrictive and does not open fully.
madonminis
Member #: 9371
East Yorkshire
Now then, would be interested in seeing a pic of the old turbo technics set up. sounds different
fred05
Member #: 10709
Gap
hi to TM!
evad1980
Member #: 10165
Stansted, Essex
Greetings!
