| Home > Help Needed / General Tech Chat > Will not start - Strange happenings? | |||||||
90 Posts Member #: 10229 Advanced Member Stroud |
5th Jan, 2014 at 12:05:23pm
I have done a search but nothing answers my questions.
![]() 1751 Posts Member #: 10190 Post Whore belgium |
5th Jan, 2014 at 12:40:11pm
I had that once with a standard engine. Still don't know what went wrong really ( was 18 and didn't work on the car myself those days) but it had something to do with the flywheel not mounted correct. Leaving the crank end totally in deep scores. you can do anything if you set your mind to it...
5th Jan, 2014 at 12:52:41pm
Pugs out, dry bores, clean plugs, drain old fuel, put new fuel in try again Drives
5th Jan, 2014 at 12:53:16pm
Check you cabling for the coil pack and crank sensor. If it's out you will get a spark, but not necessarily when you need it. On 11th Feb, 2015 robert said:
5th Jan, 2014 at 12:59:38pm
foot on the clutch would suggest crank thrusts are fucked
5th Jan, 2014 at 02:50:49pm
It is more likely a spark timing issue.
5th Jan, 2014 at 03:21:49pm
Thanks for all the replies guys. I totally agree with stevieturbo, i need to solve what is causing the clutch problem before progressing. I replaced the clutch release bearing before the engine went in the car and adjusted the clutch accordingly. Could it just be an adjustment issue?
5th Jan, 2014 at 03:32:04pm
If the wires to the coil pack are the wrong way round, it could be firing the wrong plugs. Make sure the crank sensor is clean and in the right place. I've had swarf on the sensor causing poor starting and running. On 11th Feb, 2015 robert said:
5th Jan, 2014 at 03:39:39pm
No the coil pack is wired correctly. Checked that hundreds of times. And the crank sensor is clean also, its brand new in fact. I would like to mention that this is a new engine. The guy i bought it from had it running for 5 mins but never did any miles on it. |
5th Jan, 2014 at 04:44:13pm
Is your plug order correct? Remember with wasted spark it 1-1 2-2 3-3 4-4. I run a supercharger and I don't care the TB is on the wrong side.
5th Jan, 2014 at 06:04:54pm
What do you mean plug order? No 1 closest to rad. |
5th Jan, 2014 at 06:12:41pm
yep so
5th Jan, 2014 at 07:22:02pm
Oh i understand now, yes they are in that order. I am still more concerned with my clutch issue for the moment to be honest! |
5th Jan, 2014 at 07:36:48pm
Ooo yes you need to look at that! I run a supercharger and I don't care the TB is on the wrong side.
5th Jan, 2014 at 07:36:59pm
with the clutches in mini's being so hard, I'm not supprised that the starter cant cope,
5th Jan, 2014 at 09:10:18pm
In my experience, new thrusts tend to bind up a little until they have bedded in. In addition if you are using a heavier clutch along with the inadequate inertia starter, turning the engine over with the clutch disengaged will be near impossible. On 26th Oct, 2004 TurboDave16v said:
5th Jan, 2014 at 09:11:27pm
Hi Joe, this seems pointless though as surely it will lead to further problems when the engine is running. For example changing gear? I have never known an engine not be able to turn over with the clutch depressed? |
5th Jan, 2014 at 09:43:37pm
with somthing like a grey or double grey clutch you have 1100-1200lb of force against the thrusts,
5th Jan, 2014 at 10:01:48pm
Thanks Joe, that makes much more sense now. I will get the engine running and see what happens afterwards. |
78 Posts Member #: 9073 Advanced Member Edinburgh |
9th Jan, 2014 at 01:28:00pm
Do you have a decent engine earth strap?
