Home > General Chat > Gearbox bearings
In the process of rebuilding the box for the turbo and need to order some bearings. Anyone got any recommendations for suppliers before i go down the usual route of minispares?
Rob
Minispares
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
Jon at Guessworks
16V project underway
I've never had an issue with M.S. and guessworks.
Cheers guys. I've looked at both at pretty much seems to be about the same price
Turbo Tim
Member #: 177
Woburn Sands
can't fault John for service
Amp
Member #: 7856
I believe if you are a member on theminiforum you get a discount with Minispares which may make them cheapest?
dont we get a discount? i am sure we did
I got 5% last time I ordered.
back on this and just checking prices and stumbled on this deal; have my reservations as there is nothing to confirm the suppliers. All comments welcome!
http://www.minisport.com/ms4016-gearbox-be...kit-a-plus.html
Don't!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
as above.
just confirmed my thoughts!
I think I only used the third motion double roller as that was an RHP, the diff bearings were chinese, still in the boxes, and the needles in all the other bearings were ever so slightly shorter than the originals, consequently were thrown in the bin.
They may be ok to rebuild a gearbox on a standard engine, but not something that breaths a bit heavier *wink*
good bit of first hand knowledge Colin; cheers. Minispares it will be
markl1963
Member #: 10740
B48
http://www.shop4autoparts.net/Mini/Mini_Ge..._MINI_3RDM.html
Any good, is RHP bearing?
That's a pretty good price Mark. to be honest, I've got vouchers to use at minispares and as I need a few other bits as well, I'll likely go with them
