| Home > General Chat > What Coil on plugs are these? | |||||||
6th Jan, 2014 at 10:49:58pm
anyone tell just by looking?
Edited by Brett on 6th Jan, 2014. Yes i moved to the darkside |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
6th Jan, 2014 at 10:58:43pm
Im not sure but it looks smart! On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
6th Jan, 2014 at 11:19:02pm
s2000 i think
6th Jan, 2014 at 11:23:36pm
yes s2000
Edited by wolfie on 6th Jan, 2014. Crystal Sound Audio said:
6th Jan, 2014 at 11:40:31pm
Brings me to another question, is there a way of replacing the ford coil pack for coil on plug in a megajolt setup? On 26th Jan, 2012 Tom Fenton said:
6th Jan, 2014 at 11:46:26pm
cheers lads
7th Jan, 2014 at 09:08:12am
Yes but the coils need either built in ignitors or you need one of these http://www.efi-parts.co.uk/index.php?productID=259 Crystal Sound Audio said:
7th Jan, 2014 at 12:29:49pm
This guy has used Ford ones, they look like they'll work and fit perfectly with a little bracketry on a 5 port. http://forums.hybridz.org/topic/97322-edis...illet-aluminum/ On 26th Jan, 2012 Tom Fenton said:
8th Jan, 2014 at 12:20:26am
Is MJ not stuck with EDIS coils ?
8th Jan, 2014 at 12:25:18am
You still have to use the Edis in conjunction with megajolt, but not the big bulky ford coilpack it seems. I'm willing to give it a go after doing some reading up. Some people use two Edis units, each firing two coils, but some have used one and has been okay. On 26th Jan, 2012 Tom Fenton said:
8th Jan, 2014 at 12:26:15am
http://www.autosportlabs.org/viewtopic.php?t=1359 On 26th Jan, 2012 Tom Fenton said:
8th Jan, 2014 at 07:25:58am
A single EDIS module should be able to charge two COPs in parallel, it might have a shorter life as the IGBT chips (the high current transistors) will be carrying twice the current when doing so but they are normally well over-rated.
8th Jan, 2014 at 09:10:16am
I did notice there were two types, a 3 pin and two pin, so a 2 pin coil is used it should be fine? Sorry for the thread hijacking Brett haha On 26th Jan, 2012 Tom Fenton said:
8th Jan, 2014 at 10:07:07am
Yes, Sorry Brett Schrödinger's cat - so which one am I ??? |
8th Jan, 2014 at 10:54:25am
8th Jan, 2014 at 01:12:23pm
the edis should be ok i would make sure its mounted correctly onto body though as the mountings are its heatsink
Edited by Brett on 8th Jan, 2014. Yes i moved to the darkside |
8th Jan, 2014 at 10:52:01pm
I've seen bike engines with two COP wired in series to give you the 'wasted spark'
Edited by Sprocket on 8th Jan, 2014. On 26th Oct, 2004 TurboDave16v said:
8th Jan, 2014 at 11:41:54pm
You can buy inductive COP's too. Ive seen mention that some motorbikes use them. And inductive can still have 3 wires, although it is more normal to have 2 wires.
9th Jan, 2014 at 07:34:18am
It'll be for my 1380 T3 build when I eventually get round to it. If you scroll up and have a look at my link to the ford coilpacks they would fit well, I think the key is having a flexible cop and not a rigid one. On 26th Jan, 2012 Tom Fenton said:
9th Jan, 2014 at 08:44:47am
On 8th Jan, 2014 Sprocket said:
I was also led to believe that using two coils on one output was BAD as in essence you have halved the impedance and doubled the current, but the main reason I was told is that it is an increase in transient voltage that kills the output. A fair comment but I think mitigated by two things; The first I mentioned before, the IGBTs inside the EDIS are likely to be well over-rated. eg, the ones I use (obviously driving the coilpack direct, no EDIS, but the modern equivilant of what's inside an EDIS) are IRGB14C40 and their maximum current is 20A. Estimated peak charge current of the Ford coilpack at 3.5mS is 7-8A. The IRGB14C40 also has inbuilt protection against excessive induced (transient as you call it) voltages which could be created if the inductance of the coil was too low. Granted, the ones inside an EDIS are not likely to be exactly the same (if only because of the age of EDIS) but I expect the same principles apply. Secondly though, I doubt a single COP is the same inductance as a Ford Coilpack to start with. COPs don't have to produce a high enough voltage to jump two gaps in series like a true wasted spark coilpack does. Just a theory without a COP in front of me to measure (and measuring inductance is hard anyway) but the DC resistance (which is the simple part to measure) of a Ford coilpack is a lot lower than that of a standard Lucas 12V (non ballast) coil. However I think Brett's point, that I overlooked yesterday, is probably where the real issue may lie.... EDIS is fixed dwell of 3.5mS - matched to the Ford coilpack's requirements. The optimum figure for a COP may well be different, especially if using two in parallel. But if Carl wants to go down that route, I think it's worth a try. Personally I can't see the point of COP/CNPs in wasted spark mode, if I wanted to use them I would run them sequential (not possible with the MJ/EDIS setup but easy with just about any "normal" ECU or the MJ that AutoSport make specifically for sequential and logic level COPs - obviously any of those options requires a phase (cam) sensor too (which I obviously have for EFi)) but the bottom line, as Stevie says, why ??? The "standard" wasted spark coilpack seems to do the job fine, I don't think I've seen a thread on this forum where anyone was having a problem with the coilpack/HT side of things, all the issues seem to be with getting the trigger/MJ/EDIS settings right. Just my opinion. Schrödinger's cat - so which one am I ??? |
9th Jan, 2014 at 09:08:55am
The reason I may have a go at it is because IMO it could look a lot tidier, no bulky ht leads, no bulky coilpack to mount and it is just something a little different to try. I am pretty confident that it will work, but if I ever run into a problem, fitting a ford coilpack and leads would be very easy. On 26th Jan, 2012 Tom Fenton said:
