| Home > Help Needed / General Tech Chat > Favour to ask - Anyone got a complete engine lying around? | |||||||
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
8th Jan, 2014 at 07:45:34pm
I'm shipping an engine and need to build a wooden create for it. Could anyone measure the rough box size of an engine, gearbox to rocker cover, clutch plunger to crank pulley etc etc.
Edited by Mike-998 on 8th Jan, 2014. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
8th Jan, 2014 at 07:56:29pm
Use a pallet, or half pallet screw a chip board base onto it then, ratchet strap the engine well down and then. ........ use cheap chip board & 2"x 2" lats to make a box around the crate, using screws, simple and job done.
8th Jan, 2014 at 08:02:26pm
That was the plan, but most international shipping companies charge on size as well as weight, so I was going to make my own using some 2x4 and chipboard, so that shipping is cheaper. just need to know a rough size of the engine. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
8th Jan, 2014 at 08:32:52pm
You need at least half pallet so the shipping pufflers can move it about, get the forks under it. Edited by BENROSS on 8th Jan, 2014.
8th Jan, 2014 at 08:36:43pm
That's true, I'll have a look at standard pallet size so I don't make it too small. I'm getting the box made up as work though, and they don't have any pallets, just lots of chipboard and 2x4. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
8th Jan, 2014 at 08:39:05pm
i have one waiting to be fitted il have a measure in the morning Done now needs redoing lol |
8th Jan, 2014 at 08:51:52pm
Ok, Thanks
On 8th Jan, 2014 wng691s clubby said:
i have one waiting to be fitted il have a measure in the morning http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
9th Jan, 2014 at 12:25:31pm
From memory, a standard Chep pallet is 40" x 48".
Metric is for people who can't do fractions. |
![]() 308 Posts Member #: 10369 Senior Member Pickering, North Yorkshire |
9th Jan, 2014 at 02:32:37pm
If you get stuck Pete, as you're in Cov, pop to see my friend John and see if he's got one you can measure.
www.apsbikes.co.uk
9th Jan, 2014 at 05:09:03pm
roughly l30 w17 h27in hope that helps
9th Jan, 2014 at 07:25:57pm
Thanks for everyone's help, got everything i need to put it together. Cheers! http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
