Home > Help Needed / General Tech Chat > Loctite
lee.pb
Member #: 9199
Lancashire
Simple question *surprised*
What loctite is best for general rebuild (243) ?
Blue the forgiving type, not the super strength
lee.pb
Member #: 9199
Lancashire
I think the blue is 243?
jakejakejake1
Member #: 10010
Northants
The blue 243 is pretty good all rounder, especially if you/someone will be taking it apart again, some of the red ones are near impossible to get apart again.
welshdan
Member #: 1111
s wales
my bro has had issues with Loctite not holding the bottom pulley bolt. he has had the engine in and out numerous times with this issue, has ruined several std bottom bulleys, as well as a few expensive med trigger pulleys, as well as a few cranks and a rad tec radiator because the bolt kept coming undone. last time he put it together he got some sort of uprated Loctite as recommended by MED. also the bolt and thread were perfectly clean, free of contaminents each time he put it back together. this is on a hight reving na motor with 296 cam mind, I have never had issues with the usual loctite
Does he not have a locktab on it Dan? Or not tightened up enough? :S
wolfie29177
Member #: 476
The Black Countraaaaay
The uprated bolt is a round 1 so u cant use a lock tab. I used red loctite on it but when I wanted to take it back off I ended up using a breaker bar to make it shift
Masturbation is not a crime its a hobby
lee.pb
Member #: 9199
Lancashire
Also seen the MED bolt come loose on a mates mini and make a right mess of hte rad and cooling fan.
Best to get the standard pulley machined and use the lock tab.
dev 11
Member #: 9393
stoke on trent
Seems like a wank idea to me.. if its worked since 1959 leave it be...
243 is a good locktite. You need to make sure that the threads are completely clean and free of oil before applying it thoug.
lee.pb
Member #: 9199
Lancashire
Ordered *happy*
madonminis
Member #: 9371
East Yorkshire
Anyone had any experience with loctite 241?
I'm guessing it's similar too 243. But we use it at work *smiley*
vegar
Member #: 189
There is a lot of different types of loctite. Some are for stues, some for bolts or nuts. It all depends of the use.
http://www.loctite.co.uk/loctite-4087.htm?...n%253Dsearch%7c
www.shag.no
