| Home > General Chat > don't let your mate drive your mini if he has a dragster.... | |||||||
830 Posts Member #: 908 Post Whore gateshead |
13th Jan, 2014 at 10:23:41pm
or this might happen...
balls to the blower!!!
13th Jan, 2014 at 10:33:27pm
Nicely done! On 26th Oct, 2004 TurboDave16v said:
13th Jan, 2014 at 11:00:47pm
that looks like there was not enough torque on those head studs to me or the block / head are bananananas
Yes i moved to the darkside |
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
14th Jan, 2014 at 02:29:35am
i would 11 stud it too while its apart 16V project underway |
14th Jan, 2014 at 02:58:52am
That is spectacular!
14th Jan, 2014 at 06:08:08am
the studs/nuts are minispares competition head bolt set and have only been undone t times now and the head had been on since i was running the blower and running 15psi so i dont think they were loose as it would have gone way way before now.
14th Jan, 2014 at 09:36:18am
proper job! |
14th Jan, 2014 at 09:50:00am
freind of mine had the same thing but not a mini he ether didnt tighten the head right or it just compressed over time and let go as it wasnt re tightened after the first bit of run time
![]() 9326 Posts Member #: 59 First mini turbo to get in the 12's & site perv Herefordshire |
14th Jan, 2014 at 01:13:32pm
I popped mine just like that in a brief period when I changed blocks and wasn't 11 stud like the old block.
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
18th Jan, 2014 at 09:51:50pm
Been looking at the minispares comp studs, they do quote 2 torque settings.
18th Jan, 2014 at 11:51:54pm
Minispares head studs = shit! 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
19th Jan, 2014 at 03:50:29am
unless you have been given a brand new set of minispaers studs id buy ARP |
19th Jan, 2014 at 08:16:36am
On 18th Jan, 2014 eden7842 said:
Minispares head studs = shit! Ran them on the van with no issues at daft boost levels and an aggressive ignition map. On 11th Feb, 2015 robert said:
19th Jan, 2014 at 10:09:15am
And they are on my clubby now. Not had a HG failure yet. If something is worth doing, it's worth doing half of. |
19th Jan, 2014 at 11:33:35am
The thing I've found with minispares stuff is, most of it works really well, but they get the odd quality issues now and then. On 26th Jan, 2012 Tom Fenton said:
19th Jan, 2014 at 12:55:18pm
One of the lads at the club snapped the top off one of the Minispares 'uprated' studs just torquing it down, and NO, it was not the torque wrench On 26th Oct, 2004 TurboDave16v said:
19th Jan, 2014 at 07:15:36pm
I used to use the updated minispares studs, in this build I went for arp..... I run a supercharger and I don't care the TB is on the wrong side.
19th Jan, 2014 at 07:19:21pm
I was thinking of using them but think i'll keep with OEM studs or arp. What the mind can conceive the mini can achieve
19th Jan, 2014 at 07:37:43pm
hmmm. i rebuilt it today and got it running again. i took a closer look at the blown head gasket. its not a bk450 but a british gaskets one. cant think why i wouldnt of fitted a payen one last time i had the head off. just shows you if you dont fit the decent stuff, it will bite you in the arse sometime.
