Home > Technical Chat > warped head check
turbochargedstu
Member #: 908
gateshead
gonna check if my cyl head is warped or not.
im thinking surface plate, clean head with valves removed and a dti gauge. sound ok??
someone i know suggested engineers blue on the surface plate and slide the head around a bit on it. think thats a bit shit though.
praying to god it doesnt need a skim or im fucked for my wedding.........
balls to the blower!!!
I bet it's not warped. The failure in your thread I don't see being caused by a warped head.
11 stud it and get the super studs from MS. I had this failure constantly at one point. I solved it by buying a new torque wrench.
unless the head has been insanley cooked i doubt it as will says.
whats the background of the fault or faults why you removed the head stu ?
in 99% of cases it peoples "Grandads" torque wrench that they use is goosed,
well lad it was ok when i use it in the war ......lol
remember to torque the head to 55ft pounds .... no with you grandads wrench though......lol
turbochargedstu
Member #: 908
gateshead
checked my torque wrench on the calibrated analyser at work. had to do it to 65nm though as the thing is that complicated its a pain to swap. the wrench is slightly out. by about 5-8nm. i have the competition head studs fitted already wil. gonna see if i could drill it out to 11 stud in time. basically gonna have a week, and if it goes wrong. im fooked! ha
I'd have it refaced no matter what if you're unsure...
turbochargedstu
Member #: 908
gateshead
gonna check it anyway boys with the dti tomorrow. just out of curiosity. plus i can look mega fucking manly with surface plate, dti and a smart cylinder head to all the old guffers at work who think they are the know it all's.
long edge of a steel ruler?
If you've got acces to a mill, can't you put it on some parallels and clamp it to the bed then run a dti along it?
If it is warped it's only a 20min job to skim it with a flycutter.
If not, surface table on some parallels then run a dti round it.
Frog.aye
Member #: 9903
Northern California
Be aware that if you are going the 11 stud route, the stud on the front next to the thermostat is only torqued to 25lb/ft.
My machinist has a round bar that (I assume) is quite carefully machined. He rolls it around over the head and checks to see if a feeler gauge will slip under it. Not as cool as using a dial indicator and a surface plate but much faster and will give you a real good idea if the head is warped and needs a surface.
Users viewing this thread: none. (+ 2 Guests)
