| Home > Help Needed / General Tech Chat > 1098cc internal parts with ARP rod Bolts hitting block? | |||||||
15th Jan, 2014 at 10:06:40am
So im stuck between a block and con rod? "rock n hard place"
Edited by Turbo This.. on 15th Jan, 2014. |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
15th Jan, 2014 at 10:22:09am
I'm running ARP bolts in a 1098 (which is an 83.82mm stroke unless you've altered yours) with no problems at all.
Edited by Alex on 15th Jan, 2014. Metric is for people who can't do fractions. |
15th Jan, 2014 at 10:35:09am
New info...
On 15th Jan, 2014 Turbo This.. said:
ive asked them are the rods in the correct places and right way? said they tried the other way n it hit the cam so i expect they have the rods in correct...?? Ask, do they hit the cam, or the cam lobes. Was the camchain installed and timed when they tried them "the other way around"..... The rods will hit the cam lobes on most A Series engines if the cam isn't rotating in the correct sequence (ie, timed wrong or chain breaks). Schrödinger's cat - so which one am I ??? |
15th Jan, 2014 at 10:45:52am
no crank is std 1098cc throw to my knowledge..
15th Jan, 2014 at 11:36:24am
3.3" x 25.4 = 83.82mm
15th Jan, 2014 at 11:46:06am
Well I doubt they'd get it right as I believe the cam runs half the speed of the crank or something daft like that, anyhow, they could rotate the cam so that the rods clear, then rotate the crank 180 and rotate the cam around to see if it misses everything with the crank in that position? If you get my drift. On 26th Jan, 2012 Tom Fenton said:
15th Jan, 2014 at 06:37:32pm
take the hardened washers out dont like that wont the bolt head chew into the soft rod? Are these ARP bolts specifically intended for the small bore rods? and Why are you using washers under the heads of the bolts? also The 998 A+ rod bolt is as good as the ARP bolt and they never used washers. The rod material is not as soft as you make out. something else to consider if the bolts are a 'standard' length and intended for use without washers, using a washer has automatically reduced thread engagement in a highly stressed application. Simple fix...... remove the washers Edited by Sprocket on 15th Jan, 2014. On 26th Oct, 2004 TurboDave16v said:
15th Jan, 2014 at 06:42:36pm
On 15th Jan, 2014 Carlzilla said:
Well I doubt they'd get it right as I believe the cam runs half the speed of the crank or something daft like that, anyhow, they could rotate the cam so that the rods clear, then rotate the crank 180 and rotate the cam around to see if it misses everything with the crank in that position? If you get my drift. cam and crank do clash if timed incorrectly and not in the same location either. The only real way is to throw the timing gear on and roughly set it up On 26th Oct, 2004 TurboDave16v said:
15th Jan, 2014 at 07:32:44pm
Colin the arp rod bolts come with the washers
15th Jan, 2014 at 08:25:26pm
Alex yep that will teach me for not going to get the workshop book !
15th Jan, 2014 at 10:05:27pm
The rods are mounted the wrong way! On 13th Jul, 2012 Ben H said:
16th Jan, 2014 at 12:09:33am
16th Jan, 2014 at 09:24:04am
YEP!
![]() 538 Posts Member #: 9393 Use the search function before buying stuff from me... stoke on trent |
16th Jan, 2014 at 10:18:36am
Pisser |
16th Jan, 2014 at 11:25:18am
mmm made me freak haha
614 Posts Member #: 2153 Post Whore kings langley |
16th Jan, 2014 at 12:54:18pm
Are you sure these guys should be trusted to build your engine? Speeding is like masturbating, everyone does it, but not all of us film it and put it on the internet
16th Jan, 2014 at 01:01:52pm
On 16th Jan, 2014 supermotolee said:
Are you sure these guys should be trusted to build your engine? In the 13's at last!.. Just |
16th Jan, 2014 at 01:42:12pm
I do tend to agree.
16th Jan, 2014 at 01:45:50pm
One thing I will say to watch out for with the 1098 crank is that if you fit a central oil pick up pipe in the gearbox, drop the block on top then check that the crank does not catch the pick up pipe before further assembly.
16th Jan, 2014 at 01:58:44pm
Good to hear, and that's why we use this forum, it is better to ask stupid questions about things than to not bother and potentially break something. The wealth of knowledge and mostly experience on this forum is vast, there's not much on here that cannot be answered. And when that does happen, people put their heads together to come up with a solution without all the bullshit. That's why I love using this forum :)
On 16th Jan, 2014 Turbo This.. said:
mmm made me freak haha hope this is the only silly thing that that do and not something worse...
should be ready for pick up mid-end week
then i get to look like a fool asking loads of dumb questions and posting a big engine build thingy loaded with pics to make sure i do it right...
16th Jan, 2014 at 07:36:41pm
Another thing to check is that the piston skirt clears the dizzy drive. Metric is for people who can't do fractions. |
16th Jan, 2014 at 08:16:52pm
tom and alex id not thought of ether of them but then again im useing the other block to mock up in car so cant mess around with like for like combination to see how it will work
