Home > Technical Chat > mpi turbo oil feed?
adzn3k
Member #: 10715
trelawnyd north wales
How doo guys,
I cant remember if I posted on here before asking this I cant find my last post.
Im building a turbo out but usong an mpi block and head the head is going to be modified but im a lil stuck on where to feed the oil to the turbo :/
can anyone help?
Gomme
Member #: 10528
Denmark
Hi, just take the feed from the front of the block, next to the oil filter there is also a oil pressure switch there :)..
Gomme
Member #: 10528
Denmark
It`s the one to the right, if you stand in front of the engine :)..
Gomme
Gomme
Member #: 10528
Denmark
I have put the return oil, into the top of gearbox, as there are no hole on a MPI block for the fuel pump..
Gomme
There is a hole on the back, where the cam sensor goes. You could return it there with an appropriate fitting.
Gomme
Member #: 10528
Denmark
Sure there is, but its higher than the normal fuel pump plate, and with my setup it didnt work - so i put a hole in the gearbox. :)..
adzn3k
Member #: 10715
Cheers for the info guys :)
adzn3k
Member #: 10715
Can anyone point me in the direction of a T piece so I can fit an oil feed :)
I replied with an ebay link on a thread with a very similar tittle recently, have a search for that one *smiley*
adzn3k
Member #: 10715
Ok cheers
adzn3k
Member #: 10715
Looked at the link however I have a feeling the mpihas a different thread
adzn3k
Member #: 10715
Scratch that did some digging the mpi has the same thread :) part ordered *happy*
