Home > Technical Chat > Solid mounts
lee.pb
Member #: 9199
Lancashire
Ordering final bits for turbo build and thinking of fitting solid engine mounts?
Subby is mounted solid and have both additional gearbox steadies fitted but unsure of mounting the engine solid!!!!!!! Already had the quick release ones and not a fan, so whats your thoughts.
Mini is just for fun and MITP, so not worried about rattles.
If you have any fillings don't bother. If just get standard mounts (gen if poss) and give the ones with captive nuts a miss!!
My thoughts are rubber main mounts and solid steadys
Solid engine mounts will ruin everything on a road car.
Someone somewhere wrote : solid steadies will break stuff you never thought possibly could break....
I had captive ones before, they were so much better than pissing around underneath the car, I'm not sure if they were bought captive or had nuts welded on but they fit beautifully!
Star Mag
Member #: 375
Leicestershire
I have them on mine as I kept tearing the rubber ones in half. They make everything super noisy. Don't think I would want them on a road car. The engine is rock solid though!
For 10 laps, until something gives away....
lee.pb
Member #: 9199
Lancashire
Rubber mounts it is then.
lee.pb
Member #: 9199
Lancashire
welshdan
Member #: 1111
s wales
Use quick release mounts on mine with alloy engine steady mounts. Also have this setup on my daily. Increases noise a bit but wouldnt change it
afrance2905
Member #: 10512
whitby, north yorkshire
personaly i dont like those quick release mounts for to wobbily for my liking, im going for standard engine mounts then got the dsn engine steadys with one end rose jointed and the other with a bush
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
have used those quick pin ones with the lower box mounts n top std ones
had no problems with the 50-60 hp dont expect to have any problems with the turbo engine ether just fitting new "firm" polly bushes when it all goes back in
didn't notice any change in noise from std to the quick pin ones with the extra lower steady's using rubber all round
i was concerned at how soft the quick pin ones where but since the engine sits in a "taper" i dont think it can go anywhere except sit lower perhaps due to crushing slightly?
lee.pb
Member #: 9199
Lancashire
Already had the quick release ones and found it a nightmare to remove one pin when taking the engine out after 2 years, ended to just unbolting it as per a standard mount.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
some silicone spray on the pin makes things nice ive found also use some long long bent tip pliers =D
Users viewing this thread: none. (+ 2 Guests)
