| Home > Help Needed / General Tech Chat > undercrown cooling advice | |||||||
19th Jan, 2014 at 08:09:11pm
Just after some ideas with this one.
13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
19th Jan, 2014 at 08:27:55pm
BMW,
![]() 324 Posts Member #: 9441 Senior Member South Devon |
19th Jan, 2014 at 08:32:23pm
I've seen these mentioned before.
19th Jan, 2014 at 08:39:50pm
bimmer:
19th Jan, 2014 at 08:45:30pm
Get the BMW ones. I have the zetec ones and they take more maching and mods to fit. |
19th Jan, 2014 at 08:58:08pm
Does this look right? 11 11 1 739 907 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
19th Jan, 2014 at 09:05:42pm
Yes,
19th Jan, 2014 at 09:08:18pm
Brilliant, are they easy to get from general motor factors?
432 Posts Member #: 7856 Senior Member Essex |
19th Jan, 2014 at 09:16:26pm
I got mine directly from BMW using the part number, was around £30-40 if I remember correctly!
19th Jan, 2014 at 09:20:08pm
Nice crank Andy I run a supercharger and I don't care the TB is on the wrong side.
20th Jan, 2014 at 08:57:26am
im having some installed for a safety thing..
20th Jan, 2014 at 09:36:41am
Bimmer ones also have a ball and spring. They're about £30 here. In the 13's at last!.. Just |
20th Jan, 2014 at 11:27:40am
Don't forget to use a turbo pump if you using those, and especially. If your phase 2 is X drilled as well Eden.
20th Jan, 2014 at 03:49:20pm
The zetec ones also use a ball and spring; pretty much all of them do I believe. The BMW ones are priced a lot higher than most others, but are a little easier to fit. The zetec ones seem to have a very large hole in the tip as well - which I usually crimp slightly. The later zetec with the round body were easier to fit than the older ones.
Edited by turbodave16v on 20th Jan, 2014. On 17th Nov, 2014 Tom Fenton said:
20th Jan, 2014 at 07:31:45pm
Already running a turbo pump Steve
