Home > Technical Chat > Spark plugs and Ignition leads
snowfruit
Member #: 557
Ireland
Which ones are best? what is the general opinion what plugs and leads should you use?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
std rover leads...
somthing like ngk 8s (or Champions!)
Alex
AlexF
I would have thought 8's were a little "cold" ? especially if the motors pretty standard.
Always used NGK 6's when my engine was stock, and 7's when modded, run 15psi in the past on these with no problems.
Phil. *smiley*
I think the standard Metro Turbo ones are 7s. I'd recommend these as a minimum anyway.
If you are running seriouse boost use 8s (NGK BPR8ES) or the equivalent Champion if that is your preferance.
Any good quality leads will be fine, don't fall for leads that claim massive power gains, it's all bullshit.
Wil
snowfruit
Member #: 557
Ireland
7s probably to start with then, as I'll start off running 10 - 12psi
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I run 8s...
fine at 4psi and at 20 psi
alex
AlexF
snowfruit
Member #: 557
Ireland
Typical :p you think you can safely make your mind up and someone pops along and throws it all out the window :p
NGK list 6's as standard for the Metro Turbo. 7's will be fine for 10-12psi.
Phil. *smiley*
Oh, I felt sure it was 7s. I'll check later.
You're probably right though
i use them hotwire leads as they match the colour of the car lol 8mm type
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
hot wires are cheap and nasty... well the 4 I once brought literially fell apart!
alex
AlexF
can be that bad i was second to last at avon lol
merlin sell them for the race cars?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Because they sell any length and style...
Only going on the 4 I tried once!
Maybe I was unlucky!
Alex
AlexF
t3gav
Member #: 229
Gavin@minispares.com
kent
mmm www.nology.com
