| Home > Help Needed / General Tech Chat > Can I convert Goodridge brake lines to run with wilwoods? | |||||||
656 Posts Member #: 1917 AKA chargedzetec Milton Keynes |
21st Jan, 2014 at 08:13:09pm
As title.
This is FORD country, on a quiet day you can hear Vauxhalls rusting. |
21st Jan, 2014 at 08:19:13pm
I had the same problem. Ended up getting some mate up at my local hydraulics place. Google Carlton Hydraulics. On 11th Feb, 2015 robert said:
21st Jan, 2014 at 08:24:37pm
Just cut the old ends off and fit some new -3 banjo fittings. It's really easy to do. I've just done something similar recently.
In the 13's at last!.. Just |
21st Jan, 2014 at 08:29:40pm
Search on eBay for "an 3 banjo" In the 13's at last!.. Just |
21st Jan, 2014 at 08:31:11pm
the wilwoods are actually a taper thread, so you might not get a banjo bolt in before it bottoms out,
21st Jan, 2014 at 11:59:22pm
Wilwoods being american might be NPT threads. 9.85 @ 145mph
22nd Jan, 2014 at 12:59:41pm
Pretty sure my wilwood masters are NPT |
22nd Jan, 2014 at 05:36:28pm
yeah NPT sounds right, essentially a tapered UNF on mine I think On 28th Aug, 2011 Kean said:
22nd Jan, 2014 at 06:01:54pm
http://www.rallydesign.co.uk/product_info....oducts_id=13346 On 26th Oct, 2004 TurboDave16v said:
22nd Jan, 2014 at 06:10:10pm
I personally have re made the whole hose using those self assembly fittings and the correct -3 600 hose as I wasn't sure on compatibility of the Euroquip self assembly fittings with the Goodridge hose. On 26th Oct, 2004 TurboDave16v said:
