| Home > Help Needed / General Tech Chat > Spark plugs to use with ecu? | |||||||
![]() 334 Posts Member #: 6647 Avon Park Class B winner 2010/11 milton keynes |
22nd Jan, 2014 at 07:00:24pm
Well I fitted a polestar ECU and have been told that I need restricted spark plugs. I have been using B8ES for a while and have been happy with them. I've had a look on NGK website and was hoping for some B8es/r, but these don't exist.
22nd Jan, 2014 at 07:03:50pm
BCR 8ES
22nd Jan, 2014 at 07:06:01pm
Cheers Joe this is what I was looking for |
22nd Jan, 2014 at 08:25:59pm
Same as RS Turbos or RS Turbo fiesta etc 9.85 @ 145mph
23rd Jan, 2014 at 08:33:57am
I'm sure you can get the BP8 in an R. http://www.twin-turbo.co.uk
23rd Jan, 2014 at 05:25:34pm
P generally means projected nose, which in a cold plug like an 8 is less common.
23rd Jan, 2014 at 06:27:20pm
I used DCPR8E in the BMW K head engine when I ran the nitrous rather than the 6's. They still melted lol. On 26th Oct, 2004 TurboDave16v said:
9th Jul, 2019 at 10:19:30pm
If I can do a bit of thread resurrection!
10th Jul, 2019 at 09:19:47am
if i'm not mistaken, the leads might be resisted? negating the need for resistor plugs. |
10th Jul, 2019 at 09:19:51am
Doesnt R just refer to resisitive and depends on what leads you are using? |
10th Jul, 2019 at 10:43:32am
I can confirm you will need Resistor plugs and leads, swapping in non resistor pugs on mine caused he ecu to start resetting and farting about. On 28th Aug, 2011 Kean said:
10th Jul, 2019 at 12:55:18pm
Thanks joe ! Ive not found any in 9’s just 8’s !
10th Jul, 2019 at 01:01:06pm
https://rover.ebay.com/rover/0/0/0?mpre=htt...%2F192380183675 |
12th Jul, 2019 at 12:35:21am
If it's been running fine with non resistor plugs already...then never worry about it.
