| Home > General Chat > High boost Turbo dizzy! | |||||||
47 Posts Member #: 665 Member Birmingham |
23rd Jan, 2014 at 09:48:11pm
23rd Jan, 2014 at 10:02:05pm
Do you mean the dizzy has been locked to give no advance ?
23rd Jan, 2014 at 10:07:00pm
Hi Phil,
Edited by squinty on 23rd Jan, 2014. |
23rd Jan, 2014 at 10:09:11pm
I won't be the last to suggest Megajolt....
In the 13's at last!.. Just |
23rd Jan, 2014 at 10:11:28pm
I know megajolt is the way forward and will go this route next year. I have had the car for a number of years and just want it on the road standard dizzy will be fine for now. |
23rd Jan, 2014 at 10:43:47pm
If you get the car properly set up with a dizzy you will have to spend out again to have it set up with mj in a year. If you dont have a boosted engine set up with a dizzy theres a chance the engine will go pop by the time you get it set up properly with mj. Its a bit more expense but not a huge amount. Seriously consider mj |
24th Jan, 2014 at 08:10:05am
get a stock dizzy ,take out the springs , lock the advance mechanism from being able to move(or do what I have done in the past and just let it be free ) ,and keep the vacuum can on it and working ,then fix timing at 20 degrees ,and go from there .
Edited by robert on 24th Jan, 2014. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
24th Jan, 2014 at 09:46:39am
Before I went Megajolt I ran the standard Metro turbo distributor with a max advance of 28 degrees. I got 114bhp on 10psi on a rolling road with the old T3 which, at the time, I thought was amazing. |
