Home > General Chat > What rockers are these?
dischub
Member #: 8143
London
Bought these and they were described as minispares 1.5 rockers
I know it's probably a lost just from pictures, the only number I can find on it is
0308268
Thanks
Alex
Member #: 1851
Woolavington, Zummerzet
MSpares 1.5 roller tips are usually purple.
Are they full roller or roller tipped ?
dischub
Member #: 8143
London
Two more pics
Took one of the rollers off
So I'm guessing they are full roller rockers? Thing is minispares have two roller rocker sets and both the 1.3 and 1.5 are red
Thanks
Deffo full roller rockers.
Deffo full rollers. Not sure what ratio though.
Alex
Member #: 1851
Is it as simple as measuring from the centre of the adjuster to the centre of the shaft, and from the centre of the shaft to the centre of the tip to work out the ratio.
Half my head says yes of course it is, and the other half says it can't be that simple...
alaskanow0
Member #: 8466
Mansfield
They look exactly the same as a set of 1.5 full rollers I bought minispeed years ago.
Edited by alaskanow0 on 27th Jan, 2014.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
i think you might get a ball park ratio doing it that way
better to measure it installed tho
wasn't there something about poor build quality at some point? something to do with the adjustor screws
The adjuster screws split as the hex was too big, they make them smaller now so the problem is fixed.
Theyre identical to my rockers, if you put them on a table (as if fitted to an engine) with the rocker horizontal then lift the adjuster end 1/4" the roller tip end should go down 3/8" if theyre 1.5 ratio
wolfie29177
Member #: 476
The Black Countraaaaay
Look identical to my 1.5 ratio from minispares as others have said
Masturbation is not a crime its a hobby
