Home > General Chat > heat shield for bulkhead box?
having pulled the engine out the mini, I've found the paint has blistered off the bottom of the turbo box so I need to come up with a repair and some possible solution to prevent further deterioration.
I'm thinking of a reflective mat but has anyone got any ideas? What have you done to prevent heat damage?
cheers
Rob
Genuine carbon heat shield?
Seriously though there is heat resistant sticky back mat type stuff or even a turbo blanket?
lee.pb
Member #: 9199
Lancashire
http://www.ebay.co.uk/itm/Motorcycle-Self-...=item5d4419a243
I used this
https://www.merlinmotorsport.co.uk/p/2-laye...00mm-aero-nim-l
works a treat
cheers guys; will have a look at the properties of both
turbochargedstu
Member #: 908
gateshead
i have riveted some pieces of TI sheet to the box to try and stop it a little.
balls to the blower!!!
Others just attach aluminium or stainless to the box, anything metallic and shiny really.
that will do for radiation but what about conduction ? you want something non metallic in confined spaces like that imo
Evoderby
Member #: 9987
Amsterdam
Dynamat do a heat reflective material as well, makes your mini whisper quiet*wink*
afrance2905
Member #: 10512
whitby, north yorkshire
gold is the best reflective
Tupers
Member #: 9441
South Devon
Shinny gold. http://www.demon-tweeks.co.uk/motorsport/h...-reflect-a-gold
Didn't realise how many options i could have!
madonminis
Member #: 9371
East Yorkshire
Speed tape (stick on ally tape)
turbochargedstu
Member #: 908
gateshead
i can get speed tape by the dozen!
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
why not get yourself a tidy turbo blanket?
they look grate and are built to keep the heat where it should be pushed out the tail pipe... not in the engine bay...
also helps turbo spool? or so the sellers of the blankets say..
Or go the same way as windersurfer and cut up a stainless steel sauce pan
LOL
I'd forgotten abotu the saucepan!!
The saucepan idea looked quite smart in all honesty, I never realised it was actually a saucepan until I read about it on here haha.
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
haha if it works then its a good idea and if its cheep its Evan better
