| Home > Help Needed / General Tech Chat > Oil fed crank thrusts | |||||||
30th Jan, 2014 at 01:33:51pm
I know there is a post on here somewhere but I can't find it :(
30th Jan, 2014 at 01:54:20pm
this one?
30th Jan, 2014 at 05:49:29pm
I gave my block and thrusts to Carl, it was very easy On 11th Feb, 2015 robert said:
30th Jan, 2014 at 08:21:29pm
jim dont forget to use a turbo oil pump for the extra capacity needed especially if you have an X drilled cam.
30th Jan, 2014 at 08:25:55pm
Jim has 3 cams! If something is worth doing, it's worth doing half of. |
30th Jan, 2014 at 08:37:56pm
no need Steve, oil fed thrusts. under crown oil jets and cross drilled cams in the Twinnie, and more oil pressure than I need on standard AE pumps, I have never bought a supposedly fancy pump.ever
On 30th Jan, 2014 BENROSS said:
jim dont forget to use a turbo oil pump for the extra capacity needed especially if you have an X drilled cam. |
30th Jan, 2014 at 09:09:20pm
i hear what your saying carl
Edited by BENROSS on 30th Jan, 2014.
![]() 359 Posts Member #: 8931 Senior Member Herefordshire |
30th Jan, 2014 at 10:05:56pm
I'm with apbellamy. Shoved my block in the post and sent it up to Carl |
30th Jan, 2014 at 11:38:38pm
Aren't you using an RTS Jim?
In the 13's at last!.. Just |
30th Jan, 2014 at 11:39:02pm
Or is this not for the yellow'un? In the 13's at last!.. Just |
31st Jan, 2014 at 01:45:20pm
I've never used and RTS, worried about the weight on a race engine. thanks for the link Rob On 15th May, 2009 TurboDave said:
31st Jan, 2014 at 03:39:56pm
jim, the weight would only effect you in gears where you cannot spin the wheels , you got any of those ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
31st Jan, 2014 at 04:41:07pm
31st Jan, 2014 at 07:34:21pm
Oh Taff, don't forget the £30 levy if you use my idea, |
31st Jan, 2014 at 07:45:00pm
On 31st Jan, 2014 fastcarl said:
Oh Taff, don't forget the £30 levy if you use my idea, Scene from Vic Reeves Big Night Out "that was my idea" On 26th Oct, 2004 TurboDave16v said:
