Home > Help Needed / General Tech Chat > Boost gauge
flyingturd
Member #: 4008
near cardiff np12
I've plumbed in my boost gauge, will it work on just a quick rev or not until it's under load of driving thanks
welshdan
Member #: 1111
s wales
its basically a vaccum gauge, when you rev the engine it should flip into neg boost if this is on your gauge. you wont see 'boost', apart from maybe a tiny spike into it and back when revving hard, until the engine is under load, ie driving, and the engine is actually making boost. dan
flyingturd
Member #: 4008
near cardiff np12
When I rev I get nothing
take it off and suck/blow down a pipe it should move a fraction (or use a foot pump) if it doesn't move then it's broken. If it does move then your plumbing in the car is wrong.
flyingturd
Member #: 4008
near cardiff np12
Ok it works when I suck and blow!!! *wink*
I've a pipe off the dump valve with a T piece to the gauge and inlet manifold
Either blocked or something else wrong then :) start at the beginning.
Gauge under bonnet connected to manifold nipple etc.
You need to be out on the road driving. You won't make boost sitting on the drive revving it.
flyingturd
Member #: 4008
near cardiff np12
Top people problem solved inlet manifold nipple was blocked
flyingturd
Member #: 4008
near cardiff np12
Anyone good with rev counters??
Ok I have a rev counter in my mini it's a 80mm and works fine
I want to down size to a 52mm I have bought 2 gauges one won't work and the other as soon as you start the car goes to max revs??
He will make vacuum tho :)
