| Home > Help Needed / General Tech Chat > Con rod bolts | |||||||
83 Posts Member #: 9728 Advanced Member West bromwich |
31st Jan, 2014 at 06:59:52pm
What con rod bolts where in The std turbo engine.
31st Jan, 2014 at 07:25:59pm
as far as i know there was no special turbo rod bolts Yes i moved to the darkside |
31st Jan, 2014 at 07:32:34pm
So do I really need to use uprated con rod bolts, or could I use std 1275 ones, Do I have to use new or can I use the ones that came out.
31st Jan, 2014 at 07:42:56pm
they are the most stressed bolts in an engine,
31st Jan, 2014 at 07:45:47pm
Yep my sentiments too. When they let go rod bolts can cost you your rods, pistons, gearbox/casing, crank, block, head etc!! If something is worth doing, it's worth doing half of. |
31st Jan, 2014 at 08:03:13pm
as above, all the failures i have ever known is people using secondhand standard rodbolts, NEVER skimp in this area use ARPs job done peice of mind.
31st Jan, 2014 at 08:51:20pm
yes, the std A+ rod bolts are strong, ok to 8k or more... but you only need one weak one from 100+k of abuse...
31st Jan, 2014 at 09:29:09pm
ok then looks that way then arp it is going to have to save up a bit then |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
31st Jan, 2014 at 09:35:47pm
Its well worth the expenses as if one lets go its bye bye engine.
31st Jan, 2014 at 10:07:05pm
True I will def get a set before I put together
31st Jan, 2014 at 11:37:38pm
i have never heard of an ARP rod bolt letting go ............... if it was installed and correctley torqued up.............
1st Feb, 2014 at 12:46:18am
To be honest, I can't recall a singe rod bolt failure of any kind reported here at all.
In the 13's at last!.. Just |
1st Feb, 2014 at 03:50:47am
ive not herd of any reports of bad bolts or rods for that matter but for what its worth in terms of if that bolt lets go the engine and box is most likely trash... imo the best money spent on an engine..
1st Feb, 2014 at 08:09:44am
On 31st Jan, 2014 BENROSS said:
i have never heard of an ARP rod bolt letting go ............... if it was installed and correctley torqued up............. i may be wrong though .........ANY ONE ? Yep seen several. But in all honesty it has always been because of a lack of lubrication causing bearing failure and the bolt being the weakest link lets go. I can't see an issue using OEM bolts if its going to be a motor for the road, but for the price difference it's worth going ARP. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1st Feb, 2014 at 09:26:34am
I will be using the arp like you say its a lot of work if anything goes wrong |
1st Feb, 2014 at 10:41:31am
It's the right decision and I totally agree with the comments above. In the 13's at last!.. Just |
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
1st Feb, 2014 at 11:02:22am
What about mains bolts? Is it worthwhile getting a new or ARP set? http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
1st Feb, 2014 at 03:21:33pm
No Mike not needed unless you you have open check book and your a real nerd....lol
1st Feb, 2014 at 04:03:05pm
One thing to note about the main bolts, is that some centre strap kits have/had poor quality bolts supplied. It's worth checking that you don't have these fitted. Easily identifiable as they have 3 'dashes' on the head instead of the standard 6.
1st Feb, 2014 at 06:41:21pm
Yeah the mains bolts are well up to the job, although I do like to fit studs intead, but I like stuff like that....
1st Feb, 2014 at 06:43:14pm
Thanks guys, just the rod bolts on the shopping list then http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
1st Feb, 2014 at 08:31:20pm
998 or 1275?
1st Feb, 2014 at 08:41:38pm
998 - and too late! ordered a set this afternoon http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
