| Home > Technical Chat > Supercharger vacumn advance | |||||||
108 Posts Member #: 9182 Advanced Member |
31st Jan, 2014 at 10:14:01pm
Helping out a friend building a road going 1275 supercharged clubman. He is not technicly minded so didn't want to use a programmable ignition system so after some investigation we decided on a special order dizzy from H&H. Its a suck through system and I'm wondering should the vacumn advance be taken off at the carb or manifold? |
1st Feb, 2014 at 08:27:19am
5th Feb, 2014 at 05:30:53pm
Thanks |
6th Feb, 2014 at 07:32:03pm
Anywhere between the throttle and intake valve will see vacuum when you need to see vacuum. 9.85 @ 145mph
9th Feb, 2014 at 11:59:33am
The location of the takeoff in the carb is right at the butterfly for better idel/low speed pickup. So this still preferable or is it the inlet manifold. Is there any sicence behind the location or what are people doing in practice. |
