| Home > Help Needed / General Tech Chat > Fuel in vac pipes. | |||||||
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
2nd Feb, 2014 at 09:54:48pm
Hi
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
2nd Feb, 2014 at 10:01:14pm
Plumb the gauge further away from the engine if possible, preferably before the carb. Tee off the plenum if possible. On 26th Jan, 2012 Tom Fenton said:
2nd Feb, 2014 at 10:52:45pm
If it's a mechanical boost gauge, internals will likely be brass.
2nd Feb, 2014 at 10:54:06pm
You should be reading boost pressure at the manifold as this is what the engine 'sees'. In the 13's at last!.. Just |
![]() 2975 Posts Member #: 10749 Post Whore lowestoft suffolk |
2nd Feb, 2014 at 10:54:50pm
Ive had fuel too but in the vacuum to the dump valve.. ive now faced it down so not to perish the diaphragm, but now youve worried me if it can knacker guage and megajolt??? On 24th Oct, 2015 jonny f said:
Nothing gets past Dave lol NOTHING GETS PAST ME!!
1/4 mile 14.7 @ 96mph 12psi boost Showdown class A 2nd place 18.6 @ 69mph |
2nd Feb, 2014 at 11:32:05pm
It's mechanical, but a stepper motor electronic jobby I think. Only a cheap one though, about £30.
2nd Feb, 2014 at 11:36:28pm
Search Minispares for 'fuel trap' On 26th Oct, 2004 TurboDave16v said:
3rd Feb, 2014 at 12:08:21am
Awesome thanks, didn't realise it was actually a mini specific part! On 25th Sep, 2009 mini13 said:
3rd Feb, 2014 at 11:02:17am
On 2nd Feb, 2014 1293 sprite said:
It's mechanical, but a stepper motor electronic jobby I think. Only a cheap one though, about £30. My main concern is the megajolt, don't want to fry the map sensor inside. I'm sure I read about a one way valve type thing to stop the fuel, just can't find anything on it now. Map sensors should always be mounted higher than any fuel, and always with the hose inlet pointing down. That way no fuel should ever reach the sensor. 9.85 @ 145mph
