| Home > General Chat > etb digi dash | |||||||
![]() 131 Posts Member #: 10521 Advanced Member Aberdeen |
5th Feb, 2014 at 08:47:08am
He ive bought a etb digi for my xe conversion which im no longer doing.
Flat oot like a dukes fit! |
5th Feb, 2014 at 09:09:56am
If you're not wheelspinning it should be accurate if you calibrate it correctly, doesn't matter what car you're in, if you're spinning up the speed reading is incorrect, unless the reading is taken from the non drive wheels. Hope that helps somewhat! On 26th Jan, 2012 Tom Fenton said:
5th Feb, 2014 at 09:25:00am
id put it on the rear magnet on the drum and little mount off the back plate
Yes i moved to the darkside |
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
5th Feb, 2014 at 10:08:06am
Sensor mounted through rear backplate and magnets glued to counter sunk screw in the rotating hub. Class C 3rd Place Avon 2011 14.18 @101mph |
5th Feb, 2014 at 10:36:48am
Cheers never thought about the back.
Edited by Baz_rsp on 5th Feb, 2014. Flat oot like a dukes fit! |
5th Feb, 2014 at 11:35:10am
On 5th Feb, 2014 Baz_rsp said: Yes, the diff allows the wheel on the inside of a corner to rotate slower than the one on the outside. But unless it's a very tight corner at very high speed, the difference is tiny when it comes to accuracy of overal speed measurement.
I wasn't meaning wheel spinning was thinking more on how the diff works on corners. Same is true for the rear wheels without a diff, the one on the inside will be slightly slower on a bend/corner. But I would go for the back, much easier. Schrödinger's cat - so which one am I ??? |
5th Feb, 2014 at 12:05:42pm
Ok thanks I'll see if I can but a longer cable for the sensor. Flat oot like a dukes fit! |
![]() 178 Posts Member #: 10196 Advanced Member |
5th Feb, 2014 at 07:58:32pm
I think you can buy an adapter (not from etb) that will screw into the standard speedo drive.
5th Feb, 2014 at 08:34:40pm
Ok cool I'll google it. Don't suppose you remember where you got it from? Flat oot like a dukes fit! |
