| Home > Help Needed / General Tech Chat > Running problems, help needed - N/A 1275 HIF44 | |||||||
![]() 180 Posts Member #: 1432 Advanced Member Kent |
5th Feb, 2014 at 05:38:50pm
Hello chaps
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
5th Feb, 2014 at 06:16:42pm
what needle is in the carb is it correct Done now needs redoing lol |
5th Feb, 2014 at 06:41:57pm
A point I meant to ask.
5th Feb, 2014 at 07:39:48pm
letters on needle then look on line or vizzards bible Done now needs redoing lol |
5th Feb, 2014 at 08:20:40pm
Vacum leak on the carb and or manifold, vacum, dizzy pipe to manifold, Carb, breather pipe to carb split or insecure?
7th Feb, 2014 at 05:50:14pm
On 5th Feb, 2014 wng691s clubby said:
letters on needle then look on line or vizzards bible Thanks, I will be checking that shortly. On 5th Feb, 2014 BENROSS said:
Vacum leak on the carb and or manifold, vacum, dizzy pipe to manifold, Carb, breather pipe to carb split or insecure? Check the above out first! I've replaced the dizzy to carb pipe, that is fine. The crank feed from the carb is blocked off, I checked, replaced and re-secured this. Last time I ran the car I seemed to notice what seemed to be exhaust gases coming from under the carb/between the bulkhead and engine. I put this down to residue on the manifold burning off from where it has been stored in the garage with the bonnet off. Is there any chance that this could be the signs of a faulty gasket causing the constant stalling? Should removing both manifolds and carb, reinstalling with a new gasket set along with checking the needle and replacing if (most likely) needed solve my running problem? Thanks for all of the advice so far! |
7th Feb, 2014 at 08:15:25pm
Keep us posted
