| Home > Wanted > stem seals for 8mm metro turbo valves | |||||||
63 Posts Member #: 10715 Advanced Member trelawnyd north wales |
7th Feb, 2014 at 08:30:35am
How doo guys,
7th Feb, 2014 at 08:57:01am
They used to come in the DK451 kit but not sure if they still do. If something is worth doing, it's worth doing half of. |
7th Feb, 2014 at 08:58:23am
I've got a ton of these if they were supplied in DK451's.
In the 13's at last!.. Just |
7th Feb, 2014 at 09:00:26am
Hold on. Are you sure the 8mm (exhaust valves) ever had stem seals fitted? I'm pretty sure that the DK451 only came with a pack of 4 seals for the inlets. In the 13's at last!.. Just |
7th Feb, 2014 at 09:05:08am
I always fit 8 wherever possible, just because really. Can't hurt anything On 26th Jan, 2012 Tom Fenton said:
7th Feb, 2014 at 09:07:00am
I've pulled a few standard turbo heads apart and they have em on. Also sure there used to be some bigger stem seals in the gasket drawer at Andy's.
7th Feb, 2014 at 09:09:16am
MRA is still trading I think, I've seen some Facebook activity, might be worth asking. On 26th Jan, 2012 Tom Fenton said:
7th Feb, 2014 at 09:23:37am
I've sent a message to mini spares asking if the do.
7th Feb, 2014 at 09:33:21am
If you are using an MPI head why don't you just install normal stem diameter stainless valves and use normal stem seals? If something is worth doing, it's worth doing half of. |
7th Feb, 2014 at 10:10:43am
That was my plan but then I got these for a good price |
7th Feb, 2014 at 08:43:42pm
On 7th Feb, 2014 John said:
Also sure there used to be some bigger stem seals in the gasket drawer at Andy's.! Feel free to come round and dig them out John. On 11th Feb, 2015 robert said:
7th Feb, 2014 at 09:23:13pm
If you find some let me know :) |
7th Feb, 2014 at 09:35:34pm
Bollocks. Forgot to look when I was in the garage earlier. I'll have to check on Monday now. In the 13's at last!.. Just |
7th Feb, 2014 at 09:59:17pm
Ok no worries.
8th Feb, 2014 at 06:52:54pm
I found after much trawling of the net for valve stem seal dimensions that seals intended for some Fiestas fit. They are viton with the metal body and fit nicely with a little tap into place.
8th Feb, 2014 at 08:17:25pm
Have you used these? |
8th Feb, 2014 at 08:26:31pm
Bet they are the ones MRA used to sell. Can you find some for 6mm stems now :) If something is worth doing, it's worth doing half of. |
9th Feb, 2014 at 02:34:15am
Is that 6 quid each? That would workout more than the valves cost me posted lol |
9th Feb, 2014 at 05:58:03pm
Yes, I have them fitted. Probably only done a couple of hundred miles, but I don't expect any problems. They are £4.83 each, as it says, but you could use the info on the auction to buy some from a motor factors. |
9th Feb, 2014 at 08:34:58pm
Yeah I'll see what I can find cheers mate |
19th Feb, 2014 at 07:02:35pm
On 8th Feb, 2014 John said:
Bet they are the ones MRA used to sell. Can you find some for 6mm stems now :) |
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
24th Jul, 2020 at 05:37:59pm
Post resurrection!
25th Jul, 2020 at 10:39:21am
Just stretch the standard ones to fit. I don’t think there was ever a specific one for the 8mm stem from the factory.
