| Home > Help Needed / General Tech Chat > POR 15 peeling off subframe! Better alternatives???? | |||||||
![]() 151 Posts Member #: 5593 Advanced Member Taunton, South West |
8th Feb, 2014 at 11:54:20am
I went halves with another member on this forum for a big tin of POR 15 paint thinking it was going to be the mutts nuts! Truth is, on both of our subframes, it has started to peel off...it comes off in a very thin film. I thought the whole idea of this expensive stuff was that it really ate into the metal meaning if you chipped the paint off, the surrounding areas were still completely protected...this can't be the case if it peels off like a film :/
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
8th Feb, 2014 at 12:27:00pm
Not an answer to your question but ive just painted mine in the stuff too. I used the sterling silver and at the mo still looks pretty good but it has just been sat in my garage.
8th Feb, 2014 at 12:29:01pm
front subframe? oil residue? On 28th Aug, 2011 Kean said:
450 Posts Member #: 10396 Advanced Member Formerly mk2turbo Stoke-on-Trent |
8th Feb, 2014 at 01:02:58pm
I would use epoxy mastic, I swear by it. If you get a big tin of the jotun stuff then it's not too expensive. I have only used the rustbuster one but its a bit pricy |
8th Feb, 2014 at 01:20:55pm
rear subframe, and no oil residue. wire brushed and wiped in spirits before it was applied.
8th Feb, 2014 at 01:22:03pm
I know it says it should be applied direct to rusty surfaces....but what if you're using it as a preventative measure and therefore don't have any rust to apply it to? ...surely your subframe doesn't have to be rusty for it to work.? |
8th Feb, 2014 at 01:25:32pm
wiped with what? white spirit?
8th Feb, 2014 at 01:36:00pm
If you are doing it properly you use three of their products - marine clean, primer and then por15.
8th Feb, 2014 at 01:39:58pm
Thing is though, it gets bloody expensive using all Por products....and as you know, every single company "recommends" their own products to use alongside one you've already bought. There has to be alternatives to prep the metal correctly without buying their overpriced prep kit. Edited by Mowen123 on 8th Feb, 2014. |
8th Feb, 2014 at 01:44:20pm
gets more expensive if you use only one cause they peel off!
8th Feb, 2014 at 01:52:05pm
On 8th Feb, 2014 Joe C said:
gets more expensive if you use only one cause they peel off! Ive used theire tank sealing stuff and its really good, the claning stuff really gets things back to bare metal, inside of my tanks looked like they'd been sodablasted. I agree! If it's an absolute requirement that their "metal ready" is needed before Por15, then it should be supplied with it IMO |
8th Feb, 2014 at 02:08:51pm
remove subframe, strip it and have it powdercoated.
8th Feb, 2014 at 02:34:33pm
Its the preparation on the metal. Lots of people degrease but dont do it properly. You need to wipe it on and wipe it off again without letting it evaporate. If it does evaporate it just leaves the grease on the part again. All surfaces need a good key for the paint to stick to aswell.
I seriously doubt it! |
8th Feb, 2014 at 03:36:58pm
mine are powdercoated and still look great 10+ years on
9th Feb, 2014 at 09:01:05am
only experience ive had with paint is on the body of cars and i totally agree preparation is everything !
